The Johannes Michelsen Grind
Doug Thompson near Cleveland
>Brian, in another post you asked about the grind, here's a couple pictures that might help. We talk about different jig settings and nose angles but IMO this is the best grind and the one I try to copy. This is not a picture of my personal tools (I don't want anyone to spill there coffee laughing) but a grind done buy Johannes hinself.
I'm going to email Johannes and see if he could explain more.
(hope the picture is sized correctly)
Re: The Johannes Michelsen Grind
>and the side view. Notice the bevel is very small.
Brian McInturff
>I know it's probably easier than I'm thinking but I just want to make sure I don't mess up. Since no motorized sharpening system is used, keeping the approximate angle and shape is my main concern.
Oh, by the way, 22 bowls without sharpening your bowl gouge. Finally sharpened it today. Granted, I don't use it exclusively but still. WOW!!
Johannes Michelsen
>The most important thing to remember about this grind is that the intent is to maintian the same angle all around the bevel, that is of course in relation to the inside of the flute. this is not doable with any grinding jig that I know of, you can set the angle at 40 up front but when you swing to the side you wind up with a very thin edge that I call the hook monster, this is obviously not a good thing, it's where all those catches come from. the Michelsen grind eliminates all that by rolling the tool as you swing creating taht continuous bevel that can be seen as two fat cheeks when the tool is viewed from above, these are the catch preventers; if you have a bevel to ride on you can't get a catch. There are many other bennies as well to the Michelsen grind and I could never hope to do it justice with words alone so I intend to do a short video on YouTube to show it and the grinding aid I have created for others to accomplish my grind with, much like the video I already did about HannesTool on YouTube last weekend. so if a picture is worth 1000 words then a video must be worth at least a mil. watch for it!! Hannes
Where on You Tube???
adrien
>Johannes, you mentioned your video on You Tube. I found a neat one by Mike Mahoney, but couldn't find the one you said you'd done last week. do you have a site location for it?
TIA
Re: Where on You Tube???
Brian McInturff
>Just do a search on you tube for Hannestool. it will pop right up.
Re: Where on You Tube??? *LINK*
Johannes Michelsen
>Yes Adrian I am still on YouTube and thanx Brian all you need do is go to Youtube and search for HannesTool but to make it easier I wnet and got the link so you can just click yourself in.
HannesTool
