handle length and gouge position
RogerC
>How does one hold a bowl gouge when hollowing out a bowl? Is it usually parallel to the bed, slightly angled upwards or downwards?
Most of what is out there suggest a 16" to 18" handle for bowl gouges.
I'm new to this and am working off an old gap bed lathe with the center about 5.5" above the lathe bed.
I made a 17" test handle out of scrap, and when it's held with the tip slightly upwards, the handle hits the bed.
So, am I holding it wrong, or are the recommended 16"-18" handles more suited for outboard turning VS lathe bed turning?
Re: handle length and gouge position
Re:The cutting tip should be ........
Jamie Donaldson
>...angled up and tool rest positioned to allow the cut to end in the center of the bowl bottom. This is a reason for the larger swing capacity of bowl lathes, and the lathe you are using is better suited for spindle turning, or very small bowls made with small, short tools.
>Roger Sometimes just raising the tool rest a little will help the handle clear the bed. If you cut with the flute facing closer to 3 oclock it will also help you stay on the bevel with the handle a little higher. You do want to cut with the tip on the center line of the bowl although you can start at the lip of the bowl with the tip a little higher.
robo hippy
>I have always held my gouge handles level. The gouge flute is rounded, and you will almost always have a shear cut no matter how you hold the handle and present the flute/cutting edge. Even if you are doing a scraping cut, you can still rub the bevel and get a shear cut with the nose. Do what feels best to you.
robo hippy
GaryG in MD
>Roger,
Bill Grumbine's first video shows the main cuts you can do with a bowl gouge. It's well worth the investment for that alone, and you will find many other valuable insights on it. ...Gary
Barry Elder
>Roger, all these answers represent many years of experience. Very good advice!
After you become more comfortable with the basic techniques (which would happen much faster if you were to visit the nearest woodturning club meeting) you may adopt some advice from one of my mentors and that is: The first rule is there is no rule. You must adapt any "rule" so that it fits your style.
And the other side of the coin, protect your face, lungs, eyes, and hands, no matter the cost!
RogerC
>Thank you all.
I think I'll just make it long, try it out, and if it's too long, just chop it down.
These days, I believe cabin-fever is robbing me of common sense.
