Turning yard limbs
Turning yard limbs
Turning yard limbs
Tony - Memphis
>The question about crepe myrtle reminded me of my own question! I cut some pretty big limbs from a yoshino cherry and a wax myrtle last year. These are 2-4" in diameter. They have been fairly protected outside for at least a year now. What should I do to use a few pieces for turning handles or other small stuff? I'm concerned about bringing bugs into my shop. A buddy of mine just found powder post beetles very active in his stack in his garage shop. I've never attempted to use anything from my yard, so this is unkown territory for me.
Thanks,
Tony
Re: Turning yard limbs
Bill Hale / The Wood Spinner
>Tony
You can rough out the pieces and then plastic bag them with insect spray. Seal and leave for a few weeks and all should be ok. As these pieces are a little small you may want to turn end grain. If you do you can drill a small hole in the bottom of the wet turned piece to help cracking. Cure it till dry and finish turn the piece. Plug the small hole in the bottom and do your finish.
Good turning and be safe
Bill in CG, AZ.
Barbara Gill, Remlik VA
>I am not sure I would want to turn wood that has been sprayed with insect spray. There are a number of ways to kill powder post beetles, larva and eggs. Do a Google search and I think you will find quite a bit of information.
Nuke 'em
Ken Grunke from SW WI
>Rough turn the wood first, then cook the little buggers. An unturned chunk will probably crack bad in a microwave or any forced heat situation.
Or boil the wood, no need to rough turn.
Soak in denatured alcohol might get most of the bugs.
>Barbara
Many insect sprays have a fairly short life. An example is when you spray fruit you can eat in a few days for most chemicals.
As always with chemicals READ THE LABLE.
Bill
