Sprayer Recomended?
Glenn Hodges, Nashville, GA
>After reading the post about the positive results of a sprayer vs the can spray in applying lacquer. Please let me know which sprayer, and special tip you would recomend, thanks.
Sprayer Recomended?
Re: Sprayer Recomended? *LINK*
>Glen,
The link is to the mini gun I got for X-mas. This was to complement my full-size HVLP rig for detail finishing and to do double duty in spray finishing turnings.
Comes with two top cups and 3 tip/air-cap sets so you can spray most anything from solvent lacquers and shellac to waterborne acrylic lacquers and conversion varnishes.
Have used it for toning and sealing a piece and was very impressed. In my view, this is a perfect little gun for turners. You going to be running it at somewhere around 20psi or less so you need a regulator. If you don't have one on your compressor, the place has several mini line regulators at less that $20 that will fit right on the handle of this gun. I have a regulator on my air hose, but I also put one of the minis in the gun for even finer control.
mm
Mini Gun
Allen Neighbors
>I bought a cheap, Buffalo spray gun from a good old place here in town about 10 years ago. I bought it to replace the cheap, Buffalo spray gun that I bought about 10 years before that, that I blew up.
I spray lacquer only with it... never anything else... and I clean the whole gun about every 10 years :) by replacing it.
I unscrew the fan tip and drop it into a small jar of lacquer thinner about once or twice a month, and leave it overnight. I've had lacquer in that spray gun since I bought it, and haven't done anything to it except refill it when needed. I've let it hang on it's nail for 6 months between uses, with the lacquer in it, and pick it up and rub my finger across the tip and use it. Lacquer melts lacquer.
I use Pre-catalyzed lacquer, but any lacquer will work in this gun.
I never could afford a Binks spray gun, that's why I bought this cheap one. :)
Darryl
>Glenn, You might want to check out the "Critter" spray gun. It runs about $39.95 on Amazon. Uses a pint mason jar as the fluid cup. Easy to clean with a jar of lacquer attached in place of the paint jar. Only down side is that you can not adjust the spray patter as you could with more expensive units.
For an occasional 10 of 15 item spray job it can't be beat. I have sprayed lacquer mostly but did spray some latex house paint as well. You probably need to consider a compressor with a pressure adjustment which most have. I usually need about 45 lbs pressure the cfm requirement is very low.
Mike Jones, Redding, CA
>AT 97.00, This is a GREAT gun for turners. Adjust the spray pattern down to air-brush size or open it up for a table top.
http://www.tcpglobal.com/spraygundepot/itemdetail.aspx?itemno=SHA+248752
Mark Kauder, Phenix City, AL
>The sprayer that Mark M. linked to looks to be a fine deal. Mark M and I like fine equipment. We both have some highend spray guns.
Having said that: I have a $500 Apollo spray gun, and have several $40-60 guns. What do I use 90% of the time, the two that I got at HD/Walmart. Most of us are spraying small (relatively) turned objects, not some huge dining room table. I find my HPLV gut to be finicky about the viscosity of lacquer, pressures, etc, and seems to want to be cleaned often to work well. The cheap guns go and go and go.
Frankly, I wish I had the $500 back (though I would take a look at the one Mark linked to).
Mark
28psi pressure for lacquer in this gun.
Allen Neighbors
