Decorated Oak Sphere
Brian Hahn in SW Wisconsin
>Red oak sphere, 2-3/4" diameter. Incised and colored with acrylic paints, finished with Deft spray lacquer. The stand is turned from polyester resin.
Comments and critiques welcome.
Re: Decorated Oak Sphere
Robert Henderson
>Very nice work, Brian!
How do you control the length of the stripes?
>Good Job. I've always wanted to do one of those but have never taken the time. I hope mine comes out as good as yours when I do get the time.
I know how you do it, but could you post
steve antonucci
>a picture of your holding rig for the offcenter work? I think I know how I would do it, but I'm betting there's an easier way.
Thanks
S
>The stripes are cut with the sphere turning off-center. The depth of the cut controls the length of the stripe. The angles of the cuts control the relative width to length.
Off-center cup centers
>I started with lumps of masking tape on one side of my cup centers, but that was a nuisance and I could never remember how many layers of tape to use. I also tried tape on the sides of the tapers, and that's how I made these off-center cup centers.
Close-up of the cup center
Ingenious. Thanks...
steve antonucci
>I knew it was way, way easier than what I had in mind :-)
Steven
>John, turning the sphere is the easy part. Painting the grooves with different colors (that sphere has 16 colors) literally takes hours.
>Brian could you paint the grooves with colored markers at the same time your cutting them. Believe me I know how long it takes to paint stuff like that and that's why I thought you did such a great job.
Jennifer@Indy.USA
>Brian this is cool. I like it a lot. Now could you help me in making some spheres that are 1/4"-3/8" in diameter? I've tried but just can't do it :)
Jen
tube or ring gouge
>>...spheres that are 1/4"-3/8" in diameter
Are these for jewelry?
I've read about using a metal tube to turn spheres but I haven't tried it. Mike Darlow calls this a "tube gouge" and illustrates making perfect spheres on the end of a piece of wood gripped in a chuck using a steel tube he sharpened. He also shows turning some very small bead-sized spheres by using a ring tool in the same way. This is on page 102-103 in his book "Woodturning Methods". (Excellent book, BTW.)
I found another reference but I don't have the magazine issue to check it out:
"Tip shows a method for turning wooden balls which utilizes a sharpened steel tube as the lathe tool."
WOODTURNING #50 Mar 1997 pg. 4
>Jen, I tried a ring gouge like John K Jordan mentioned, but at least on spheres this size, it was a disaster. I've seen people make spheres with a skew, but that takes a bit of practice. Personally, I'd buy spheres that size from a hobby store like Michaels. :))
>Brian I tried using the round pipe also. It was disastrous. Brian Simmons showed us a good way to get a perfectly round sphere. You take a round ring and rotate it on top of the sphere. Any high or low areas are immediately seen. Then I use the skew on it's side to fine tune these areas.
Another method that works is to take the lens out of a flashlight and then put the round ring on the surface of the sphere. The light shines shines through any low places so you take of the high areas. This is similar to the ring method above.
It doesn't have to be a fancy ring. Just take a chunk of PVC and turn it round and then part of a slice.
Re: tube or ring gouge
>Darlow warns that the ring/tube must be slightly smaller than the sphere. If the sphere is turned one tiny bit too much it will jam in the ring/tube and cause a disaster.
Re: tube or ring gouge *LINK*
Jennifer@Indy.USA
>Nope, John they are for the little balls that I put in my Wish Bowls. For now I just buy them at Michaels and then decorate them with my burner. If I actually turned each one of them I'd never get any made.
Jen :)
WISH BOWLS
noob question
Tom Sontag - St. Louis
>This kind of begs the question in my feeble brain: how did you get the cup off center? I understand off center work between centers as it were, but cup/bowls?
I tried this
>I tried making a tube gouge (actually more of a tube scraper) and made some small spheres this afternoon. I'll try to take a photo.
Re: noob question
>I put a small lump of masking tape on one side of the Morse taper on the bottom (thin end) and a matching lump closer to the top on the other side. This made the taper sit at an angle in the socket. I turned the cup, then removed the masking tape lumps. The result was a cup center with an off-center cup. I made a second cup with a shorter taper for the live center in the tail stock.
Did that answer your question?
