>I am getting ready to turn 8 Ruth Niles bottle stoppers on a commission job. I am using the threaded stoppers and need to know whether or not I should apply glue to the threads and top of the stopper or just screw them in without glue. Thanks for any info that can be provided.
I've turned lots of these with Ruth's threaded tenons. Like so many things in woodworking, the answer seems to be "it depends"!
I would say that 95% of the time, I drop a few drops of CA Thin glue in the hole and then screw in the stopper. Note that I dry screw them in first and then take them back out, just to be sure that the threads are all cut cleanly in the stopper blank. In fact, I've got a "dedicated" stopper that I use for this purpose. That way, I can grab it with the plyers and don't care that it gets scuffed up.
There's only be a few very dense woods that I haven't glued in. Lignum vitae comes to mind, as does verawood. For everything else I've done, I drop in a few drops of the thin and then quickly screw in the stopper!
Good luck,
Mike
Gotten one or two stuck and had to start over in Apex, NC!!
>>...Gotten one or two stuck and had to start over in Apex, NC!!
Stuck from CA glue setting up too quickly? If so, what I do when gluing pens is to put the pieces in the freezer for a while first. The cold slows down the CA reaction and increases working time.
>I read that somewhere else also so this time I will ask; why in the world would you need to put the thing in the dishwasher? I just rinse mine off and dry. If wine gets under the "o" rings, they can be removed.
Why do you not glue? Typical usage and habits in Spain might be different from here, so I know you have a good reason.
I usually put a little Titebond III in the hole and assemble. Reasoning (perhaps faulty)is that most right-handed people will tend to "unscrew" the stopper when removing it from the bottle, and best if it does not come apart at this time.
1) Mine fit so tightly to the thread I would never get them tightened in time before the CA set. Also the wood will move and I wonder in 12 months or so whether the glue is still doing anything.
2) Some of my stoppers have delicate decoration on the top. A couple of customers have broken pieces off. They have returned them and I have re-fitted them to the lathe and reshaped and refinished them (their choice not mine). This would not have been possible had they been glued.
These comments only relate to threaded stopper bases with the plain shaft bases that Ruth supplies you have no choice you must use glue of some sort and in this case I use silicone so it can move with the wood (if necessary).
