Can Anyone Stop Dogwood From Cracking?------WebKit
Emmett Manley------WebKitFormBoundaryeC5T7JtK+bIB1
>I am fortunate to have access to lots of large dogwood trees (4-9" diameter), some alive, some dead, some dying. The wood is absolutely spectacular but I am unable to keep it from cracking. I have tried letting it dry in the woods, in various shelters, and with the ends painted. Nothing seems to work. A few days after turning some beautiful item the cracks begin. Any ideas?
------WebKitFormBoundaryeC5T7JtK+bIB12EK
Re: Can Anyone Stop Dogwood From Cracking?------WebKit
Gary Evans Tallassee, TN
>Hi Emmett,
My experience is that if you leave the pith in a piece of dogwood it is going to crack. That said, if you cut the pith out of a 4" piece of dogwood you don't have much wood left.
You might build a box that you can control the humidity in and experiment with drying the wood more slowly than if it is air dried. You might also try bagging the whole piece in paper bags. Slowing the moisture loss is about the only tool you have available.
Gary
>I have never been able to save dogwood in the log form. I turn it into thin bowls or I cut it up into 3x3xas long as I can and seal the ends. I still lose a lot of that but there are usually enough pieces left for ornaments and boxes after it's dry.
>Same experience - I cut the dogwood into blanks as soon as possible and let them air dry with the ends coated. I have lost very little.
One thing that might make a difference - I was fortunate to get some big dogwood (in excess of 12" across) and I wonder if large diameters may be more stable than smaller diameters.
Another thing - looking at my firewood pile, some specific trees might be less stable than others. I see a few 4"-6" diameters with huge fissures extending from the bark to the pith, while others have no apparent cracks. Drying very slowly may also help - any rounds I've brought into the shop have always cracked severely while much of the firewood had stayed in piles on the ground (out in the rain) for at least a year. I've also noticed that like persimmon, dogwood trees that appear to have been standing dead for a number of years never seem to crack, although they may be full of worm holes.
>Thanks to all for reinforcing what I feared -- dogwood is as difficult as it is beautiful. One experienced woodturner told me to "turn quick and turn thin" and still be prepared for dogwood to break your heart. Looks like my dogwood will be restricted to bottle stoppers and other relatively small items.
georgetroy
>I would reduce the limb logs to slabs and use it for segmented turning, then all you need to do is seal the ends. Use a moisture meter and when down to 6-8 % make into segmented bowls.
Dick Hines
Dick Hines
>I got some dogwood last spring that was so fresh the tree guy that brought it to me said "This had blooms on this morning." I roughed out all the bowls I could and soaked them in DNA. Not one crack in the bunch. I don't know if I was lucky or what.
DNA is how I treat all my wet wood turnings. DAN is upo to about $15 a gal. at Lowe's but it saves a lot of bowls for me so I think it is worth it.
Emmett Manley, Lakeland, TN
>Dick, This sounds interesting but I am a bit confused. You mention both DNA and DAN. Which is it? What is it? The DNA I know does not seem that it would be involved in preventing cracking. Deoxyribonucleic acid (DNA) is a nucleic acid that contains the genetic instructions used in the development and functioning of all known living organisms.
So, the substance must be DAN. What is DAN?
Thanks, Emmett
Don at Central Illinois
>It is DNA, denatured alcohol. Do an archive search for denatured alcohol soak method of drying.
