dyes
dyes
dyes
Mark Paulley
>Hello everyone!
Recently some awesome dyed pieces with a glass like finish have been posted.
What type of dyes are these individuals using? Water based, alcohol based?
Brand?
Pro/Cons on H2O vs Alc?
Thanks for the help!!!!!!!!!!!!!
Mark
Re: dyes
Re: dyes
>Mark I prefer the water based. They are easy to mix and hold the color longer than alcohol. I need to look at the metalic dyes because they last the longest. Gary Sanders did a test a few years ago where he used several different types of dyes and a bunch of colors. He put the finished product in the dash of his truck in sunny texas. Almost all of the colors completely faded in one month except some of the water based and most of the metallic dyes.
I buy red, green, yellow, blue, black, and brown. with those colors I can mix any color.
You do need to raise the grain first and sand it down but that should just be an extra step like sanding to a finer grit.
They are transparent dyes so you can overlap 2 colors and get a third. Very handy in some situations and problems in others. I have trouble controlling them to fine areas because they want to bleed through the pores and grain lines of the wood. They can also penetrate completely through thin wood. I found this out the hard way with a white vessel that I dyed the inside black. I had black spots all over the outside. If you wood burn a line it will stop the bleed but of course this has to be part of your design.
Re: dyes
Re: dyes
Mark Paulley
>John,
Thanks for the info. I too learned the hard way on thin walled vessels. Did the same thing as you but its was a spray can of flat black paint.
Just don't see how these guys dye these great looking vessels. The dyes looked very controlled in their placement.
Mark
Re: dyes
Re: dyes
Brian Hahn in SW Wisconsin
>As John mentioned, all dyes are fugitive, at least all of the dyes I've tested. Some colors are better than others, but they all fade rather quickly in sunlight.
For a more permanent coloring and easier to control coloring, consider thin washes of artists colors - inks, water colors, oil paints, acrylic paints, etc. Some of the pigments are transparent and a thin wash of an opaque pigment is virtually transparent. The pigments in these colors have colorfast ratings of decades to centuries. Also, the pigments are very finely milled which makes them more transparent than traditional wood stains - and also more expensive. But a little goes a long way.
An air brush is an easy way to control the placement and intensity of color. (I'm going to learn how to use my air brush today.)
Re: dyes
Brian and John-THANKS!!!!!!!!
Mark Paulley
