Hunter Tool - Sweet Spot?
Barry Turner
>I got a new Hunter # 4 for Christmas. For some reason, I can't seem to find the tool's "sweet spot". I'm beginning to think my tool was shipped without one. Seriously, the tool just seems unstable. I can't seem to rub the bevel or get the tool to cut where I want it to. I tried yesterday to use it to do the final finish cut on the inside of a 6" maple bowl. Well, let's just say that was NOT the final finish cut......or even close! What am I doing wrong?
Re: Hunter Tool - Sweet Spot?
>Barry Get a scrap piece of wood and face it off. Then take the Hunter tool and tilt it about 45 degrees. Now rub the bevel so it not cutting. Then move the handle in the direction you want the tool to cut. When it starts cutting your on the sweet spot. Try cutting from the center out and then try some from the outside in. This will help you learn to find the sweet spot.
When you have this down try rotating the tool to about 35 degrees and then back to about 55 or more. You will have to move the handle a little as you go from one to the other but this lets you learn to use the tool.
If all else fails drive to Baxter and I'll give you the crash course.
Texian
>John,
Opportunity for you to do a photographic tutorial? Just some still photos showing tool presentation orientation for various cuts. I.D., O.D., face, bottom of box, etc. Got the #3 & #4 cutters and screws, made a couple tools, use them frequently and like 'em a lot.
>Next time I'm in the shop I'll try to make some photos.
Why the Hunter tool?
Dave Peebles Lyons, Ohio!
>Hi Barry,
I am curious why you would use the Hunter tool on a bowl? It seems that a bowl gouge would be the tool of choice.
Don't get me wrong, I have heard that it is a great tool and works really well for many things. I saw John Lucas do some great turning with it at Indyfest. But I am just trying to educate myself.
If you are just doing it to see how it will do, that is great.I like to experiment myself. :)
Just wondering...
Thanks,
Dave
Re: Why the Hunter tool?
>I would agree with Dave. It it's an endgrain bowl I can see using it but for a side grain bowl I think a bowl gouge will give you more control for a cleaner line and just as good a finish.
Using the Hunter tool is kind of like doing a pull cut. You don't have as much control of the cutting arc.
Now if you have really abrasive things in the wood I would choose the Hunter.
Ric Taylor
Ric Taylor
>Barry,
I think one of your troubles results from trying to use the bevel of the Hunter. The Hunter isn't like a bowl gauge, the trick is positioning the cutting edge to do the work. Don't try to ride the bevel, it doesn't apply to this tool.
Ric
Bill Hale / The Wood Spinner
>John
You to use it on abrasive wood ? Most of the wood I turn is high silica content and it does dull tools fast. My question is that the Hunter being a non sharpen tool will it not wear out faster and end up costing more than conventional tools.
Bill in CG, AZ.
You can't sharpen the Hunter tool?
David Walser
>I'm asking. I bought a couple of tools that are very similar to the Hunter Tool off of ebay about 3 years ago. The tools have carbide cutters mounted on a steel shaft (with golf grips for handles!). When one part of the cutter gets dull (it takes a long time!), you simply rotate the cutting head to a fresh edge. When the entire cutter is dull, you can remove it from the tool and sharpen it. Tormek and others make jigs for this purpose. Is the Hunter Tool's cutter fixed in such a way that you cannot remove the cutter for sharpening?
Here are links to a couple of the jigs that could be used to sharpen the cutters on my version of the Hunter Tool:
Tormek jig
Woodcut jig
Re: You can't sharpen the Hunter tool?
>they are carbide and will hold an edge for very long time. As David said if you dull it rotate it. It can be replaced. I don't think you can sharpen it on the tormek. It would groove your wheel very badly if it would sharpen it at all. It's my understanding that you need a green wheel to sharpen carbide cutters. I do have a green wheel and will make one of those attachments for it if mine ever get dull just to see if it would work.
The Hunter tools fit in a custom cutout on the bar. If you changed the size of the tool very much you would open up a gap that could trap debri. If that would be a problem I don't know. Probably not until the gap got pretty large.
>Depending on how you use the tool you do ride the bevel. For example when you start at the bottom of a box you are riding the bevel. When you come up the sides you are off the bevel, or at least it looks that way.
Re: The Eliminator Easier ?
Bruce McElhaney, Spring Lake, Michigan
>Don't want to to change the subject, but just wondered if the Eliminator (which is a similar tool to the Hunter) might be easier to use than the Hunter? I understand it has flat spots on the bar at 45 deg. to keep the correct angle of the cutter to the wood.
Steven Antonucci
I tried sharpening carbide on my Tormek
steve antonucci
>Ain't happenin'
S
would need a diamond wheel or hone to sharpen
>The angle is not really the problem it's more in the left and right attitude of the handle. You can cut with the cutter at almost any angle from about 25 degrees up to 90. 35 and 45 are common although I tend to use them closer to 55 degrees for what I do.
Thanks for pointing out my mistake...
David Walser
>Seriously, thank you. My advice could have ruined someone's grinding wheel (like my own). When my cutters get dull -- in another five years at the rate I'm going -- I'll need to get a green wheel.
Re: would need a diamond wheel or hone to sharpen
>John Your right. If I was going to sharpen one I'd probably just rig a chuck for my drill press and hold a diamond hone to the outside. Dremel also sells green wheels but I think that would be hit or miss.
I made my own Hunter tools and...
keith zimmerman, Normal IL
>I ground the flat for the cutter square. This created a gap between the cutter and the bar and I have not had any problems with debris buildup.
keithz
I agree 100% John...
>you describe what it is like to a 't'. My experience with the tool is exactly that.
keithz
>I have a couple of industrial diamond wheels, about 6" diameter, that want to set up to experiment with. It would be fun to try to shape and sharpen my own carbide tools.
I've not yet found a good reference, but I'm thinking diamond wheels should turn at a very slow speed and be flooded with water similar to a Tormak or perhaps with a small water pump. I have a variable speed sewing machine motor I think will work if I can machine the proper tapered arbor to fit. I suspect the axial alignment needs to be perfect - seems like it would be pert near impossible to dress a diamond wheel to run true!
Barry Turner
>The problem with the Hunter's cup-shaped cutter is that the bevel is on the inside of the "cup", making it difficult to get to. But, I'm sure you could figure out a way to sharpen it. After all, it was sharpened once!
Barry Turner
>You may be right. I was also holding the tool with the handle down, like with a bowl gouge, instead of horizontally as in the photo's.
Resharpening: Voice of reality
James McClure
>For just a few bucks you can replace the cutters, so is it really worth the time and effort to try to resharpen it? Someone over on WoW posted a link to a site that carries these cutters:
http://www.carbidedepot.com/
These are the ones he was using:
RCGT0803MOHP
RCGT1004MOHP
RCGT1204MOHP
The downside is that you have to order 5 or 10 at a time.
Re: Resharpening: Voice of reality
Ron in Drums PA
>I found I like the 11 degree relief angle (M) better than the 7 degree relief angle(C). Seems to cut better and easier to use.
I also found that spraying WD-40 on a diamond hone, then making 5 circles with the bit face down is all you need to sharpen these bits.
