Hollowforms R'Us
Hollowforms R'Us
Steven Antonucci
Hollowforms R'Us
steve antonucci
>I've been working through a lot of smaller blocks. Honestly, I have so much wood right now, all conveniently frozen to the ground, that I haven't really thought about what the heck I'll do when I'm done? Luckily, I had a stash of smaller blocks inside to keep me busy.
Left to right:
Cherry burl
Spalted maple
Cherry burl
Spalted curly maple with ebony collar
Box elder
cherry burl with some drying cracks
Most of them are turned through a 3/8" to an 1/8" give or take. I had a natural edge on the flat curly spalted maple (#4), but lost it because I was listening to Metallica and got distracted (caught in a mosh). The depth hole was also an 1/8" too deep, and so the bottom has a 1/4" ebony plug in it that doesn't look too bad.
Overall sizes are around 4x2.5", and most weigh 2-3 ozs.
Comments always welcome.
Steve
P.S. still need touch-up sanding, and finish...
Re: Hollowforms R'Us
Cyril Griesbach
>Well done, Steve. Looks like you had some real fun. I especially like the Maple ones.
charlie belden
>REALLY nice forms and REALLY nice woods. Definitely going in my Nice Pieces Folder.
Working through a 3/8" diameter when you have a reach of almost 4" can get "interesting". I saw the pic of the small hollowing tools you posted earlier. Looks like you've got about 5-6" of steel in front of the brass ferrel, providing more than enough reach for small hollow forms. Oh - and the wood selection for the handles! Nice.
Given their size, I presume you won't be using a grinder to resharpen them but will touch up the edge with a stone or diamond plate?
Have you considered a carbide insert cutting tip? Flat top makes it quick and easy to restore an edge without much time, effort or lost of metal.
A guy in Silicon Valley Woodturners makes tools for members occassionally. He does a pair of tools for small hollwing that have a tapered shaft - starting about 3" back from the tip. Gives you a little more rigidity on "longer reaches"- if there is such a thing with stuff this size.
How are you checking the wall thickness, especially up just below the "neck" where there's not much maneuvering room?
Nice stuff. Look foreward to what all the
frozen to the ground stuff you have inspire.
charlie belden
Steven Antonucci
Thanks-some answers to your questions
steve antonucci
>I own a Tormek, and I can grind them freehand if I really need to, but I do keep a small fine diamond hone nearby to touch them up.
Light cuts at full extension, of course. 1/4" is pretty sturdy at 5" if you go slow.
Never thought of putting carbide on the tip. I do want to make a small Ellsworth style tool because it's what I learned with. I have a pile of tools that I've made with utility in mind, and I decided to make some pretty ones just because...
As far as measuring goes, I've pretty much completely switched to Ellsworth's wire calipers. I bought a bunch of armature wire and have all different shapes and sizes for making my measurements. The undercut vessel is the hardest by far to measure the "top" thickness, but it can be done with the right shape (one straight leg, the other pointing to the side of the first tip.) You can hear it in the cut as well...
Thanks for your comments.
Steve
P.S. with all of the rain, most of the ice is gone and my wood is mostly unfrozen from the ground again! Big wood=big plans...
Steven Antonucci
I have a lot of that maple
steve antonucci
>It came from a stump which was in a cut your own firewood field. not only is it spalted to perfection, but it's also curly.
One man's scrap is another man's treasure.
Thanks for commenting
s
