Two days in the shop...
Steven Antonucci
steve antonucci
>I've actually had a lot of shop time this weekend, and I went to the Somerset, NJ Woodworking Show yesterday. Life is good.
I had just ordered some steel from Enco, and it came during the week, so I was on the lookout for "handle" material. I love curly and birdseye maple, but I didn't think I was going to get what I needed. I found a guy at the show that had these blanks for $1.25 each, and I picked the best of what he had left. Today, I bought brass compression fittings and decided to turn them down. A sharp spindle gouge was all it took. The steel is 1/4" O1, and heat treated with a MAPP torch. Overall, I guess they're about 18" long.
I used them to make the flat hollowform in the picture in the next post. They cut great. The back of the handles are branded with a symbol so that I can see them easily in my tool rack behind the lathe. If I had everything in the shop when I had started, I'm guessing the set would have taken 90 minutes start to finish.
Comments welcome.
Steven
Re: Two days in the shop...
Atwerz
>Steve how far is the metal inserted into the handle? I've got three going to make handles for the first time.
David Walser
>Steve,
What kind of spindle gouge did you use to turn the brass compression nuts? I used my parting tool to touch up a copper fitting that I used to make a ferule. It was not an easy process and I'm wondering if I was using the wrong tool.
Steven Antonucci
About 3"- the length of the bit
steve antonucci
>I drilled them on the lathe, and then by hand to the length of the bit. Doesn't have to be this long, but steel is cheap.
S
Steven Antonucci
Just a regular spindle gouge.
steve antonucci
>Brass was so soft, I was amazed at how quickly it was done (30 secs?)
Steve
Re: Just a regular spindle gouge.
>I agree. I have always used a spindle gouge or bowl gouge. I had to make 3 handles the other day and used the Thompson spindle gouges. This is where they showed how much longer they hold an edge. I usually have to sharpen a couple of times when turning a long ferrule but with the Hunter I finished the ferrule and then turned the handle with it. It definitly wasn't sharp but still cut cleanly.
don lewonczyk
>John, am I right to assume you meant to say you finished the handle with the same tool you used to cut the ferrule? You were talking about the hunter tool in a previous thread and maybe thinking about that? I am not trying to be smart just want clarification. I don't spell to good either. Hey I saw an otter in my small creek around noon today, first one I have spotted in the wild, real cool. Of the Thompson tools which would be the most valuable to you in your day today turning? At turning I am only a beginner and I am impressed with all the stuff I see on this site made by all of you. I don't know where you all get the time to do it. Happy thoughts and safe turhing. DonL
Steven Antonucci
Brass turns with any woodturning tool
steve antonucci
>It's harder than wood, but softer than steel. I didn't even sharpen the spindle gouge first. Once it was round, I used some sandpaper (220 and 400) to polish it a bit.
Threw the paper away since it was contaminated with metal, but it was still good too.
Steven
>Don I did use the thompson detail gouge for the ferrule and then the handle. Even though the cutter used in the Hunter tool is used for cutting aluminum in the metal industry it doesn't work any better and maybe not as good as the thompson gouge. It won't dull as quickly but I had more trouble controlling chatter when cutting brass and aluminum.
Any HSS tool will cut brass and aluminum. You have to learn to cut slowly. If your getting little tiny curls then your cutting correctly. If you get to much chatter you may be pushing on the bevel too hard or cutting to rapidly.
Scrapers do work well but dull very quickly.
don lewonczyk
>Thanks John for clearing it up for me, I never tried to cut metal on the wood lathe. I would guess it would be possible to turn a solid brass finial, I might monkey around with something like that. DOnL
