glass like finish
Steve ponch
>Went to a show this month and saw several hollowed vessels that had a glass like finish, almost looked like ceramic. How do these guys do this?
glass like finish
Steve ponch
Re: 27 coats of lacquer will do it
Russ Fairfield
>There may be other finishes, but lacquer is what I use to get those "glassy" high gloss finishes. I use the number 27 because anything less than that doesn't get it, and 27 gives me a little extra for a final rubbing.
I can get a similar gloss with about the same number of rubbed on coats of an oil/varnish finish, but lacquer is quicker.
Others may have shortcuts to that high gloss, but I have never found one that worked for me.
Re: glass like finish *LINK*
Curt Fuller
>There's a turner here in Utah that I've always admired. He does a variety of turnings, but his dyed and lacquered burl pieces are amazing. His process must be similar to what you're talking about.
Chris Pytlik
HarryB in Downtown Kulpsville
>Kim Blat demonstrated turning hollow forms at our club meeting a few months ago. He brought some of his completed hollow forms. They were dyed and had a gloss finish that looked like you could dive into it. When asked what he used for a finsh, he rattled off a long technical sounding answer. All I got out of it was "post catylized." I believe it is a product used for automobile finishes but I'm not certain. He does beautiful work. If you are interested his web site is:
http://www.kimblattwoodturning.com/
Re: glass like finish and dyes?
Mark Paulley
>Curt,
Do you know what type of dye these guys use? I saw some of these vessels when the AAW was here in Louisville and just could not believe my eyes.
Color and DEPTH!!!!!!!!!!!!!!!!!!!!!
Tanks
Mark
Google Mark Kauder. His...
Allen Neighbors
>finishes are the best I've ever seen in my nearly 50 years in wood working.
The only other finish I've seen come close to Marks was a man who layered lace into a finish on the fenders of an 1936 ford coupe.
>Glass like finishes are easy, in theory. You simply build up enough finish so there aren't any bumps or holes from the wood showing and then sand and rub out the finish with finer grits until there aren't any scratches showing. This may require filling the pores with a grain filler or something similar.
Well that sounds easy enough but it's not. I've done glossy finishes with Polyeurethane, shellac, lacquer and True Oil(whatever that is). Let me say up front that mine don't look like Mark K's. Close maybe but not as deep or scratch free. I'm still playing when I have time.
Polyeurethane doesn't rub out as easy and you have to wait weeks for it to dry hard enough to rub out. Shellac works well and but I've never mastered the true french polish technique which really brings out it's luster. True Oil is easy and only takes about 7 coats but it has internal scratchs that to us purests just doesn't look as clear as the others.
Shellac works best for me. I haven't tried all the different brands. I'm currently using a brand Called Benco that I buy locally. It is much harder and clearer than Deft which I use to use. I can't even tell you how many coats I use because I just spray it 4 or 5 times a day while I'm doing other things. I still have to work on my final polishing things to get to Mark's level. As I said in the beginning, in theory it sounds easy, in practice it takes, well practice.
Re: Google Mark Kauder. His...
Mark Kauder, Phenix City, AL
>Thanks, Alan.
Mark
>I think that Russ has his tongue is firmly planted in his cheek when he says 27. The point is it takes as many coats as it takes. If you apply it to a very grainless would Ebony, it can be as little as 9-10 coats, with Red Oak, it can take Russ's 27+ coats.
The primary key is time - you need to dedicate whatever number of coats, and however may hours of sanding that it takes. If you don't then the only thing or person you can blame is yourself.
Also a high quality, high solids lacquer is essential. You will spend a fortune is you try to do it with a spray can lacquer, and you will have to resand/polish in a couple of months and then again in another couple of months if you waste your time using Deft.
Mark
>>...Also a high quality, high solids lacquer is essential.
Can you recommend a quality lacquer or two?
Re: 27 coats of lacquer will do it *LINK*
Roger Smith
>John, Mark directed me to a String Instrument lacquer (B611-1406, Behlen) from Grizzly. Grizzly's number is H3634.
lqcquer
I'll ask the guitar makers
>I'm going to spend the day with a custom guitar maker next Tuesday to learn more about Inlay techniques. I'll ask them about the finishes they use as well as the buffing systems.
eliot d
>Mark, People seem to turn to you on this subject. A French polish was often the finish of choice in the old days of furniture making. So how do you feel about shellac for a high gloss finish?
>One that is easy for most of us to find that is well formulated for bowls, is Behlans Stringed Instrument Lacquer. It is flexible enough to move with the wood, but tough enough to handle the handling.
I use Lawrence McFadden's Guitar Polishing lacquer. Basically the same thing, but I can easily buy it in larger quantities. McFadden's sells only to businesses and minimum orders of 2 gallons. Macfadden's customer list is basically the Who's Who of guitar manufacturers, and was recommended to me by a local guitar maker (of some fame).
Funny thing about getting lacquer though the mail: If you order a gallon or 5 gallons of Behlan's, you pay a $20 Hazmat fee. But if you order 4 quarts, you don't generally pay any hazmat fee.
Mark
George Van
>Mark, I would find it convenient to use Behlen for my small quantities. Did you also use the Behlen H4277 Vinyl Sealer when you used Behlen's product or is this just a thinned 50/50 sealer? must this always be sprayed?
>George,
I have talked to many experts about Vinyl Sealers under lacquer. Most will tell you honestly that they don't do alot, unless you have a very opened grain wood. Most of the time, after the first coat of lacquer, your wood is sealed. Some will tell you that a vinyl's purpose is to create a little flexibility between the wood and the lacquer. However, if you are using a lacquer with flexibility formulated into it, like the stringed instrument lacquers, the sealer is probably overkill and an unnecessary step.
In short, if you ever get down this way, I think I have a gallon or so that I will give you. (Would through in a gallon of grain filler).
Mark
