Maple Vessel With Branded Collar
Bill Clark
>This is the second piece of Big Leaf Maple I�ve turned and it�s a great wood to work with. It was twice turned with a soak in DNA and a drying period in between. As I was completing the final cuts I decided to try some branding. I�ve been anxious to try the branding skills I learned from Molly Winton�s demo at the AAW Symposium in Portland last summer. The collar is part of the vessel and branded to contrast with the golden maple color. The piece is 6 � � tall and 6� wide. The opening is 1 5/8� and the base is 1 ��. The walls are a true 1/8� all the way down to just above the base to add some weight. The piece was sealed with shellac and then finished with satin Minwax Wipe-On-Poly. All comments/critiques welcome.
Re: Maple Vessel With Branded Collar
Bill Clark
>Branded Collar Detail
georgetroy
>I think you did a fine job. Great shape and nice idea on the collar. That big leaf maple is a delight to turn. You are showing a high degree of skill level here. GT
Cyril Griesbach
>Bill, this is one beautiful hollow form. Your work on the collar is as excellent as it is inspirational and it all works to show off a spectacular piece of wood. Well Done!
Bill Clark
>Thanks George and Cyril. Branding the collar was a risk to a nice piece of wood. After a little practice I decided to go for it. The dark contrast and texture on the collar ended up adding another dimension to the piece so the risk payed off.
Mike Rubes, Apex, NC
>Hi Bill,
Very nice, thanks for sharing the pic. Like others have said, I really like the collar effect.
Good photos as well.
Mike
No shop time for days in Apex, NC...
John Scheideman
>You NAILED the shape.....it couldn't be a better form. And I love the collar. Very nice piece!
John
Dave Peebles Lyons, Ohio!
>Hi Bill,
What a great piece!! The burning looks really good. But Like John said, it is the killer form that really sells this one for me.
Wonderful piece,
Best wishes,
Dave
Bill Clark
>Thanks John and Dave for the comments. When I rough turned the piece I wanted to do a HF with a small base. Once it dried and I finished turned it on the outside I became concerned about the stability of the piece and that it might be too top heavy. I turned the inside down to 1/8" almost all the way down to the base to make it lighter on top. I then left a little more meat about 1" above the base to add some weight to the bottom. It seemed to work out OK and it rests nicely on the base and is stable.
Bill Clark
>Thanks Mike!
