Sharpening drill bits
Mark Paulley
>Another question!
I have found a bunch of 5/16" and 3/8" diameter x 10-12" long drill bits, the type with a rather long point on the end. I quess these are Brad point bits? These were very cheap because they are dull.
I want to make some handles and make them into depth drills.
Does anyone know how to sharpen these type of bits?
Can the point be removed and shapened on a Drill Doctor type of grinder?
Any and all help is appreciated!!!!
Mark in Cold KY
Re: Sharpening drill bits
Brian Hahn in SW Wisconsin
>I've had very poor luck sharpening brad point bits.
I'd try your second option - convert them to standard point bits and use a Drill Doctor to sharpen them.
>Mark I sharpen them with white grinding bits in my Dremel. You can get different sizes if you look around long enough. I think I might have gotten mine from www.riogrande.com but it's been so long I don't remember. They also sell cratex grinding wheels which work well if you only need to sharpen, not reshape.
Dave Peebles Lyons, Ohio!
>Hi Mark,
Do yourself a favor try to beg, borrow or steal a copy of Leonard Lee's book. It is called "The Complete Guide to Sharpening" It has a page or two on the brad points. But it is the best book on sharpening I have ever read. It covers almost everything. And yes, he is the man behind Lee Valley tools.
You may be able to find it at your local library, or request the library get it for you from the loaning program that my library has.
The ISBN number is.... 1-56158-067-8
And is published by Taunton Press.
Dave
Lee Buck
>excellent advice
