How to turn flat "disks"...
Larry In Lima
>Ok, going to try to explain what I'd like to do... I would like to take some 1x boards, cut circles about 4" through about 10" and turn them round (very), maybe a few slight embellishments on edge, but keep them very flat, and not reduce the thickness either.
I really don't want to glue them to something and part them off, and I don't want to put screw holes in them. Just think of them as nice flat disks. Is there something such as a spring loaded center or something that would hold them securely for something like this? Any other suggestions? I'm willing to take very very light cuts if needed, but just no holes, etc...
These aren't for coasters, but maybe someone who has done coasters has an idea? Thanks, Larry
Re: How to turn flat "disks"...
Rich Egan
>Larry:
Why turn them at all if you don't have to? Plane the stock as flat as possible and cut your circles with a circle cutter on the bandsaw or use a jig with your router.
>Sounds easy, Larry.
1. Cut your circles to a bit oversize.
2. Mount a waste block on each side using double-face carpet tape.
3. Mount them between centers and true them up to the precise dimension.
4. Dismount, pry off the two blocks, clean off any gun with mineral spirits.
Does that get-r-done for you or am I missing something?
Steven Antonucci
In addition to Mark's recommendations
steve antonucci
>I'd start by jointing and surface planing the rough outs. Then, I'd do the same for the waste blocks. This will insure a flush surface on both mating surfaces.
The setup should look something like a big oreo cookie with your disk being the creme...
Steven
>I would use a vacuum chuck or do them on the router. If you flatten both sides you can make a drive using a blank of wood with sandpaper on it. Then make another one for your live center. Then all you have to do is turn the outer edge.
Norm Smith
>I agree with John, Vacuum chuck is the obvious choice.
Norm
>I would smooth the surfaces by sanding or whatever method suited me. Plane then in my lunch box planer or run them through my Performax or any way that suited me to get them flat and smooth. Then I would cut the circles slightly oversized.
Mount and true up a piece of wood less than four inches across (smaller than the smallest one you want to make)on a face plate. With your tailstock, press a similar disk against the one on the face plate and clean up the edge, just for fun. Make a really good imprint of your tail center in the piece.
Then, just press your pieces between the two and turn the edges. if you are afraid they will fly away, you could use a piece of rubber mat or carpet pad on each side to provide a little grip. Or you could use PSA sandpaper on the surfaces to provide friction.
If that doesn't work, you could send them to John Lucas and let him do it. :)
Mike Jones, Redding, CA
>You don't really want to spend a bunch of money on planers and/or vacuum chucks for this project. You want to know how to do this on the lathe.
A disk of particle board or good grade of faced plywood will make a jamb chuck. The company in your area that makes counter tops has sink cutouts that have laminate faces that they'll likely give to you free...one of these will work great.
From this, rough-cut a disk at least 10" dia. and mount a face plate on the back, careful that your screws do not penetrate through the laminate face. True it up. Mount your roughed-out work piece to this jamb chuck with double face tape. Bring your live center on the tailstock up and put a penny between the point and the work piece to avoid making a hole there while "jambing" it tightly in place. Make your light cuts across the face of the workpiece to plane it smooth and to desired thickness. Use "T" square or ruler on edge to check for flatness.
To take off the penny-sized nubbin that's left, wrap fiberglass reinforced packing tape around the workpiece and the jamb chuck for safety sake, then lightly cut the nubbin away. Flip the workpiece over and repeat to do the other face.
If you cut the jamb chuck down to the precise diameter that you want for your workpiece with each successively smaller disk, centering the workpiece after reversing it will be simple.
Pretty cheap, easy as pie, no problemo...:)
Bruce McElhaney, Spring Lake, Michigan
>If you have a vacuum set up that would be great. If not, what about using Cole or Jumbo jaws? If you're only taking light cuts, they should work fine.
Have to Disagree
>With my friend John on the vacuum option.
The reason is because to turn a 4" disk, at most you can use a 3" chuck. A vacuum chuck that small, even at say 24" of hg., will have very little holding power at less than 85lbs. total atmospheric pressure. Cutting a rim as you need to do puts maximum force to the vacuum seal so you'll need the tailstock in place for safety anyway. Since you'll need the tailstock under pressure, the vacuum becomes irrelevant as your setup will essentially be a jamb chuck situation.
Vacuum is great for finishing the center of a turning's diameter where there is minimal flex and tangential force from the cut. Move out to the rim and start taking interrupted roughing cuts, and you'd best either wear full body armor or have a surgical team standing by.
mm
as always - JMO-YMMV
Band Saw...
Jorge Castaneda~Downeast Maine
RP
>I think your response was excellent. It will probably fall on deaf ears. Not hard or expensive enough!
Very Good "how to" but
>Larry's only turning the edges on the circles that range from 4" through 10" in diameter without changing the "1x" thickness of the disks. All he's doing is truing up the rims to a given diameter, and wants to avoid a pilot hole in the center of each disk.
mm
How I turn flat disks
Ron in Drums PA
>At times I'll use the tail stock with the center point removed and use a soda bottle cap so not to mar the wood (you'll notice the cap on the headstock).
Take notice to the RPMs, the camera stopped the motion.
I disagree to disagree :)
>Mark I routinely turn 3" pocket mirrors using nothing but the vacuum chuck. Granted it doesn't hold really firmly but it works fine. I learned this from Nick Cook. My most used vacuum chuck is only 4 1/2" wide and I have turned a lot of bowl bottoms using that chuck.
I'm not a math wiz, in fact Im not even close to a math wiz so I don't even worry about the math of vacuum chucks. I simply put a piece of wood on and try to pull it off. It takes a pretty good tug to pull the bowl of my 4 1/2" vacuum chuck.
I also have a 3" chuck that is 8" deep. I use that for deep vessels and still have enough holding power to turn the bottoms.
Larry In Lima
>Rich, no bandsaw, no router - but give me time!! Larry
Larry In Lima
>Mark, that sounds easy (and cheap) enough, going to give that a try I think - Larry
Larry In Lima
>Man, guys, wish I had all these tools, definitely would make it a whole lot easier, but in time, I'll "collect" a few more tools... Larry
On The Contrary
Larry In Lima
Larry . . .
>No Bandsaw? 2 additional suggestions:
1. Use a had jigsaw to rough them to a circle before you go to the lathe.
2. If the jig saw is broken, mount your blanks and turn by hand to mark a circle on the face. Set your tool rest parallel with the face, turn on the lathe, and use your parting tool from the tailstock end to cut the basic circles. Lastly trim up the rim with your bowl gouge.
Sorry, I should have mentioned the above. Trying to knock 4 points off square blanks will not be a fun time with lathe tools.
mm
Re: Larry . . .
Larry In Lima
>Thanks Mark, I'll get 'em somewhere near round, and mount and finish. Appreciate the help - Larry
