Shop built Marking knives and awls
Dominic Greco in Richboro PA
>Hello Everyone,
I figured that since this is wood turning, I'd post this here as well as over on the Handtool forum.
Here are a couple marking knives and awls I made over the past week. The first one was made from some spalted Dogwood. It had some any holes that were filled with epoxy and coffee grounds. The ferrule is a 3/8" brass compression nut that was turned smooth. The "blade"is a section of HSS left over from a bunch I had purchased from ENCO last year (I made some 3 point turning tools). Since the wood was so "busy looking", I kept the shape simple.
After this success I decided to get fancy and cut up an old planer blade and formed (2) marking knife blades. I made a simple jig to work with my Veritas Grinder Tool Rest and ground the edge. Then I got fancy and honed and polished the faces so that they shone. I then used some ebony, and some bubinga scraps to make the handles. Like before, I used compression nuts as the ferrules.
It's pretty much the same story with the bubinga awl as with the dogwood one. Except I used a section of 3/16" HSS rod as the blade. I wanted something with a bit more heft, and a steeper angle to the point.
I admit, I went a bit over the top when it came to sanding. All were sanded to 15000 grit (micro mesh). I guess that's my old pen turning influence showing up again!
The finish is multiple coats of Watco's Danish Oil followed by a coat of Renaissance Wax.
Thanks for Viewing!
See ya around,
My ugly mug
Dominic
Re: Shop built Marking knives and awls
matt overton
>nice job Domenic! Greetings from Wrightstown
Bill Clark
>Great job! These are beautiful and almost too nice to use.
>Beautiful Dominic. I really like the marking knife.
Jennifer@Indy.USA
>Dom, these are beautiful! And I thought you were hibernating :)
Thanks for sharing.
Jen
Mike Stafford
Mike Stafford
>Dominic, those are wonderful looking tools. I find the marking knife particularly attractive.
A while back I turned a bunch of awls for gifts for some turning friends. They were turned using 5/16" compression nuts for the ferrule and 6" long 5/16" drill bits for the blade.
Thanks everyone!
>I appreciate the compliments. It sure felt good to make something at the lathe. Since I started using hand tools more and more, I've been on a lathe haitus lately.
See ya around,
Dominic
Steven Antonucci
Those look pretty nice, Dom!
steve antonucci
>I think there must have been something in the water this weekend, because I also make two awls!
Both of mine were made to pick frass out of bug tunnels in an ash bowl I made. I had two smaller picks, but they were too flexible.
I really like the handle shapes and I'd be interested in hearing about how you manage to finish the cut on the backside of the awls? I think that's the hardest thing to do in turning- make it impossible to detect how it was mounted!
The marking knives are also exceptional. I have two knives I started a couple of years back in ATS34 steel that I need to send out for heat treating and cryogenic tempering, and I will eventually get to them...
Steven
Mike Rubes, Apex, NC
>Hi Dom,
Very, very nice! I like them all very much. Great detail on them and I don't think sanding that high is a problem at all! I love to make the wood shine even without a polish on it :)
Thanks for the pics, I hope things are well up in PA.
Mike
Slow and steady wins the race in Apex, NC
NO PICS
Nick Tuzzolino
>I only received the dreaded red X. What can I do to get the pic.?
Try these
>Dogwood awl and ebony marking knife
Pic 2
>Bubinga marking knife and awl
Beautiful !
Don Orr
>Thanks for posting the inspiration. I have been wanting to make some marking knives my self.
Ancient Chinese Secret!
>Steve,
Thanks for the compliments!
You wrote:
"I really like the handle shapes and I'd be interested in hearing about how you manage to finish the cut on the backside of the awls? I think that's the hardest thing to do in turning- make it impossible to detect how it was mounted!"
For the awls I used a variation on the shop built bottle stopper chuck I came up with (as featured in the article in "Woodturning Design" Nov 2007). I just made a smaller one from a scrap of appropriately sized HSS stock. Once I formed the overall shape, I was able to back off the tail stock and finish the end of the awl handle just like I do with bottle stoppers.
See ya around,
Dominic
Real beauties Dom
Craig Daymon
>Looks like you could pick up some sidework with Bridge City Toolworks.
-Craig
Got'em
Nick Tuzzolino
>Thanks, Dom. Beautiful pieces!! Nick in 80 deg So Cal
