OT Quartz Overhead Radiant Heater
ebd
ebd
>Tried some searches of the archives but didn't find anything. Has anyone user the Quartz Overhead Radiant Heater from Lee Valley?
http://www.leevalley.com/wood/page.aspx?c=2&p=44590&cat=1,43456,43465
I'd like to get something like this to take the edge off when I need to work for a short while but don't want to build a fire. The shop rarely gets below 20F.
Re: OT Quartz Overhead Radiant Heater
adrien
>don't remember where I got mine, but have one just like the picture. Works nicely for me, focussed on just where I stand to turn. Not as close as that in the Lee Valley picture. Takes the edge off until the gas line gets going (they've a two minute mandatory washout to prevent explosions) and warms up the shop. But 20� is COLD!
joaz
>I have one in our seafood shop for a couple of years. Two setting low and high. Work's great. However, I broke the string the other day which is used as on/off and settings. I can't figure out how to take the front panel off to rig something to turn it on. In the mean time i plug and unplug. This is the only complaint i have for this unit that works well in minus degree temps here in Maine. I did get it from Lee Valley.
Keith Inscho E. Tenn.
>I got one from Lee Valley a few years ago and mine works well but won't heat the shop. Because of the type of heat it is it heats what it is pointed at (you) but not the air. So for heating a spot where you you will be standing it works fine.
Bill Neddow
>I have one I bought from Lee Valley and it works great. But, remember, as Keith pointed out, it is radiant heat -- which means it heats you and the lathe (or anything else solid) and not the air. If I am toasty, it does not matter what the air is like -- you don't really notice.
Chris DiCiaccio
>I have two. Been using them for three years or more and they work great. I would buy them again.
Carol - now in NC Nebraska
>I have two. Takes a while but it gets the garage above freezing so I can turn a little. Love'em.
Carole Valentine
>Have two - one in front of me and one at my back when I am at the lathe. The front one can be swiveled to aim at the workbench area or the jet mini. Add a heated floor mat and you will be in heaven. Won't need them in my new shop though (gloat) :)
Re: I've used a commercial unit......
Jamie Donaldson
>... designed for livestock barns for many years, but watch out for a sunburn on the top of your head! Of course the fact that the hair is not as thick as it once was has contributed to the problem, but the warmth is worth the need to wear a cap at times!
How hard do they hit your elec. bill?
Allen Neighbors
Raymond Overman in SC
>I have one in a 10 by 10 space and it does a good job of keeping me toasty on those super cold 45F nights we have here in SC. I bought mine at a big box and would buy another one if mine stopped working.
I've got a thermometer in my shop and it will usually push up by 5-10 degrees if I close the doors and turn on both elements.
Impossible to find these days
Dave Peebles Lyons, Ohio!
>I am sitting under one right now!! I love it. But it seems they have vanished from the market.
There was a thread on the slow board... main board :) a few months ago. Rob said they were no longer available. If you go to the Marvin web site there is no mention either. Sooo, if anyone has a lead on where to buy one, please let me know. I would love to have a couple more.
Dave
Check here-they may have one  *LINK*
http://www.teksupply.com/farm/supplies/Search?catalogId=10053&catalogId2=10001&ftCatalogId=10001&storeId=10001&langId=-1&division=TekSupply&searchMethod=wcSearch&searchType=ANY&searchBeginIndex=0&searchDefaultPerPage=10&ftSearchBeginIndex=0&ftSearchD
Denis Putland
Re:are they a fire hazzard
Denis Putland
>as it seems to me that there is a possibility of wood chips getting caught up in the grill???
I could use some of this type of heat this year.
We just had a few days of -50c.
Denis
ebd
Re: Impossible to find these days
ebd
>Here are some links of several types:
http://www.heatershop.com/qvt22_quartz_space_heater.html
http://www.castlewholesalers.com/LAKEWOOD-QVT-22-Dual-750W-or-1500W-Fan-Forced-Quartz-Heater.html
http://www.heatershop.com/model_sun1_electric_parabolic_space_heater.html
>I had a propane version that mounted on top of the tank. It sat in my shop waiting for that really cold day. I fired it off and it happened to be sitting under the hook for my plastic coiled air hose.
In a matter of minutes the hose overheated and died of an aneurysm. Pow! And it was over. That one was definitely a fire hazard.
Stuart Johnson
>I use a single head propane heater. When it is fired up there is a brief burn off of any dust. I've yet to see any make it much past five or six inches and never anywhere near the floor.
There is a grill over the front but it is probably possible for a chip to get past it. I don't know what would happen in that case. I never leave it running if I'm not in the shop.
ebd
Thanks to all
ebd
>Thanks for all the responses and input. I found the upright model in a local hardware store for about what I could get it for online. I think it might be handier in the long run as I can move it to provide spot heat wherever I need it. I tried it out in the gagage last night while I was grilling. It took the bite out of the cold without throwing a lot of air and using a lot of power. It's just what I wanted (I think). I'll have to use it for a while to make sure, but I'm happy for now.
