chain saw question
chain saw question
chain saw question
Bill Tucker
>While helping with the tornado clean-up this weekend, I ran into problems which got worse as the day wore on. It quit cutting at about half the bar width, seemingly because the bar was binding. We are talking large oak and maple. Tried sharpening the chain repeatedly (probably did more damage than good). Is it possible that I have the wrong chain or more likely just operator error?
Stihl 028 AV with 16" bar
Oregon chain 35LG 0676 .325 .063/1,6mm
Re: chain saw question
Re: chain saw question *LINK*
>Binding? Can you move the chain by hand immediately after stopping?
Make sure the chain is not binding in the bar slot from being pinched or full of pitch/junk. It should move freely by hand. Also, check to make sure the bar slot is not worn too much and the chain is not tilting to the side. This can make the saw quit cutting or cut in a curve. If you haven't done so, flip the bar. Common advice is to flip the bar every sharpenings or so. Try your spare bar.
I clean the slot every time I flip the bar. You can clean it with a small screwdriver. Note: if the bar is bad, it can be repaired with a little roller tool. I've repaired them by hand with a screwdriver and hammer but the right tools make this so much easier.
Make sure the chain is very sharp of course. When cutting hard woods like oak and black locust I sharpen often. (Just takes one or two strokes with the file if done often enough.) Some pros I know sharpen every time they stop to fill the tank with fuel. Makes a nice safety break as well.
If you sharpen regularly and the the chain is not binding and still not cutting, it might be the depth gauges need to be filed. If you have it sharpened in a shop, don't assume the shop knows about this - the dealer where I bought my first Stihl didn't so I taught myself how to sharpen and never went back.
depth gauge and other things
Bill Hale / The Wood Spinner
>Bill
I may be wrong as it has been some time since I have had a small chainsaw. I used to have the same problem.
The 028 has a narrow cut chain and on wet wood the fibres in the cut slot will drag on the chain and bar to a point of stopping it. You may find that you need to widen the cut as you go along.
Bill in CG, AZ.
Bill Crommett
>What John says about the depth gauges is correct. My dealer would not grind my depth gauges because he said that the company forbids it. So I do it myself.
Mike Jones, Redding, CA
>If the saw is bogging down, stalling, or dying when you get a few inches into the cut, and you feel that the chain is properly sharpened and the depth guages filed, the problem might be associated with the powerhead. Old, skunky, fuel will cause that, as well as a dirty fuel filter.
Hope some of this helps!
Tight Chain
Roger Smith
>A chain that is too tight will create the same problem.
roger
Keith Tompkins
Keith Tompkins
>Bill, a couple of more hints: first, be sure your oil/fuel mixture is correct, and the carb is adjusted correctly. A lean mix will cause overheating, and loss of power....you will literally SEE the waves of heat coming off the engine!! (just before the piston seizes) Be sure the oil reservoir is nearly empty when the fuel tank is empty....the rate is adjustable. You may be running on too little chain lube.
You should see large chips when cutting....small chips or piles of dust indicate a dull or improperly sharpened chain.
You describe an unsafe condition...your saw MUST be in tip-top shape at all times! be sure to find and correct the problem. A tip for anyone not familiar with operating a chain saw.....keep your left arm locked at the elbow when operating the saw!!!
oil reservoir
That's a good point. A couple of years ago when refueling I noticed the oil tank was only 1/2 empty when it was normally nearly empty. I found I had permitted sawdust to fall in the oil tank and it had clogged the intake tube. I rinsed it out with kerosene and all was well. I'm more careful now about wiping sawdust away from the filler cap before opening.
Angelo Schembari in Cornwall, NY
>A few things come to mind:
1. Wrong gauge chain. The saw runs 0.325 pitch chain which is available in .063 and .050. The gauge for your bar should be stamped at the base somewhere. Running too wide a chain will cause binding, overheating, and can wear the clutch and bar.
2. No oil/Oil pump not working. Run the saw full throttle over something light colored. (Stump, newspaper, etc.) You should see a line of oil spatter coming off the tip of the bar onto the ground.
3. Chain too tight. Chain should be tensioned so one drive link will clear the bar when pulled up in the center of the bar.
Hope this helps.
Oregon Chain Selector
