green holly
Bill Tucker
>I just cut back an 8' tall holly tree/bush with multiple 3'sections in the 2 inch to 5 inch diameter range. Do I need to saw the lengths in half to help preclude splitting? Is there any other advise offered?
thanks
green holly
Bill Tucker
thanks
It splits
Charles R. Smith
>Congratulations on the holly. You'll love working with it -- it's my favourite wood. However, it does split badly.
I found that the best way to substantially reduce the splitting was to boil the roughed-out forms, then let it dry until the weight had stabilized (i.e., reached moisture equilibrium with its environment) before final turning. I boil holly on a big pot on the side burner of my barbeque, usually for about two hours. (I also tried drying in denatured alcohol, but it didn't reduce splitting to any degree.)
By boiling in clean water (i.e., not boiling holly with any other wood species at the same time), it doesn't appear to affect the wood's colour (or lack thereof) to any significant degree.
Charles (who has his chain saw dangerously close to a 40 foot holly tree in his back yard)
Re: green holly
>I would cut it into turning squares or rough it out as soon as possible to avoid staining and splitting. I haven't had any significant splitting, but the log sections I used were larger, 16-18" or so in diameter - maybe that made a difference. I'm ashamed to say how many big chunks of holly I've wasted by waiting too long long to process, some 24" in diameter. :( Holly that big is hard to find, at least around here.
If it stains, a friend of mine said it bleaches nicely, but I haven't tried that.
I have used the microwave technique to dry pieces 1" thick for immediate use. This took several hours of short microwave bursts with cooling to room temperature between.
I love the look of holly. When I use myland's friction polish finish, it looks a lot like ivory.
Re: green holly
Bill Crommett
>I have turned long spindles of Yaupon Holly three inches in diameter with no problem of splitting. But this may be different from the other Ilex varieties .
holly
Philip Duffy
>Seal up the ends, today! I work with lots of holly and all the advise posted is good words. I have also bleached it and that works well. It comes out looking very white. I find you can dry limbs slowly and they tend to stay pretty white without splitting but main trunk pieces need to be processed very quickly. Boiling ruff blanks is good! Phil
Re: holly
Barbara Gill, Remlik VA
>I was given some very large holly during the summer several years ago. The large 18" bowls were roughed out quickly and soaked in denatured alcohol, wrapped, etc. There was no staining and not much warp. I never have had much trouble with holly cracking.
