Baseball bats
Baseball bats
Baseball bats
Bart Rhoads
>I have been commissioned by my 9 yr old nephew to make him a baseball bat and I don't know anything about baseball bats. So, does anyone know where I can find the dimensions for a bat. I know the length will vary greatly but my main concern is have far back the taper starts, going back to the handle. And also how to determine the major diameter and the diameter of the knob at the end of the handle.
Thanks
Bart
Re: Baseball bats
Re: Baseball bats *LINK*
Raymond Overman in SC
>Here's a link to a quick search on the subject. Craft Supplies carry clear ash blanks for $25-$35.
They've got Google on the Internet now
Re: Baseball bats
Re: Baseball bats
>I don't know where you are Bart, but they have nice ash blanks (34" x 3.5" x 3.5") available in Atlanta at Atlanta Wood Products (and their sister outlet North GA Hardwoods). As I recall they were in the $15-20 range. I bought a few and turned a couple of bats and made the rest into legs for my work bench (not turned).
Re: Baseball bats
Steven Antonucci
It depends
steve antonucci
>Bats for 9 year olds are considerably smaller than the MLB versions. I believe that they are also regulated for game use (+1...) by length and width because pitchers were getting killed by balls being hit by aluminum bats.
I'd find a bat he's comfortable swinging and copy it for starters. I grew up swinging a bat that was way too heavy for me (34 oz.). One day as an adult, I picked up a "kiddie bat" at the cage (30 oz.) and I was crushing pitch after pitch. Then I read that Mike Piazza swung a 31 oz. bat...
Good luck
Steven
Re: Baseball bats
Blanks
Pete Kekel - Kentucky
>Don't pay anything near that for a blank, Bart. Depending on your timing, I'll send you one or give it to you at the SSS.
Re: Baseball bats
Re: Blanks
>Besides ash, do you know what else is good for baseball bat? I have hickory and maple but I've not yet seen an ash log here.
Re: Baseball bats
Re: Blanks
>Louisville Slugger uses Ash, Hickory and Hard Maple. Of course, if it's for decoration and not serious use anything could be used. I remember reading a while back that Barry Bonds was getting his bats made in Canada with Canadian Maple.
Our turning club toured the Slugger Museum and watched them make bats (none of them by hand anymore), and were amazed (and dismayed) at the amount of Ash that was being thrown out because of slight flaws. They couldn't be bothered to set it aside for someone to come and get.
Re: Baseball bats
Thanks for the help
Bart Rhoads
Re: Baseball bats
Re: Baseball bats
Eric Knutsen
>Bart,
This is actually why I got into turning initially. I'm 36 and still playing baseball. A few years back the NCAA came down with a ruling where the maximum differential for an aluminum bat could be -3. This means a 33 inch bat must weight 30 ounces or MORE. Bats were being made as low as -5 for adult usage. This essentially made the smallest of guys power hitters. Anyway, my league figured we'll follow suit. Then they realized that wooden bats are made at -3 so we went to wood. Again, this is for adult usage. Kids may be -5 or even -7. Check with the league for the specifics (i.e. length to weight ratio (-5, -7, etc) also the max. diameter barrel) Adult bats are 2 5/8" max. I use www.baseballbatbillets.com for my stock. If you need to adjust the overall weight of a bat, particularly if its heavily end weighted, put the finished bat in a wood vise and use a plunge router and a forstner bit or round box cove bit to hollow out some wood from the barrel end. Good luck.
Re: Baseball bats
Thanks
Bart Rhoads
