taps for threading holes
Carol - now in NC Nebraska
>I want to get some hand taps to fit the Jet mini.
As I understand it, the head spindle is 1" x 8 TPI and the Jet live center is 5/8" x 11 TPI. Correct me if I am wrong.
When I get into the catalog (MSC) I find taper ground taps, bottoming ground taps, and plug ground taps.
Which do I want?
I will be tapping plastics, MDF, and hard wood to make various chucks and other accessories. More immediately, vacuum chucks.
Re: taps for threading holes
Re: taps for threading holes *LINK*
Darrell Feltmate
>Carol
I use a standard taper ground tap but for wood any of them work. There are pictures of the process on my site.
Tapping a Glue block
Steven Kubien
>Carol,
I am not sure about the MSC and the items you were looking at but Beall makes taps for woodworkers that are very reasonably priced. Woodcraft and Lee Valley sell them.
HTH
Steve Kubien
Allen Neighbors
>Carol, a Taper-ground Tap is the starting tap. A Bottoming-ground Tap is the tap that makes threads all the way to the bottom of a hole.
I never heard of a Plug-ground Tap, so I can't tell you what it's used for. But I'm sure there is someone that will read your post that can.
The Taper-ground Tap can be used to tap threads all the way through a hole in a wooden face plate... like Darrell, that's what I have used for several years.
Darrell Feltmate's Website has never steered me wrong.
Fog Tanner
>I bought a tap for the tail stock cone from Wholesale tool. For that I bought a bottom tap since its in a blind hole. For a through hole, the tapered ground taps would work provided they will give full threads to the depth need.
For the minilathe I am trying the Bonny Klein method - cheaper than the tap. A $2 lock nut in 1"-8, turn out the nylon "lock" and glue in a block of wood. Used them in a workshop making boxes, were quick and easy. The only thing that really needs to be done is to saquare up the "face" of the nut where it contacts the spindle. That is only necessary if moving from one machine to another - like lathe to threading jig.
Gil Jones on Lake Seminole GA
>Carol, my Jet live center thread is 3/4" x 10 tpi.
I reckon any tap is ok if you are cutting the thread all the way through. If the threads are cut into a bore with a bottom, then a bottom ground tap is will cut threads deeper. I by HSS taps (bottom ground) at ENCO for my wood jigs/chucks.
http://www.use-enco.com/CGI/INSRIT?PARTPG=INSRAR2&PMAKA=325-4808&PMPXNO=5809894
eaglesc
>I purchased a 1x8 tap to make a collet chuck a few years ago.
I got it from Grizzly.
Here is a three piece set but I believe you can buy them indiividually
Taps
keith zimmerman, Normal IL
>I use a 1"x8 Beall tap for my headstock and an inexpensive bottom-ground tap for my #2 MT, which is 1/2"x20 and I use in tailstock.
keithz
>Thanks.
And thanks, Gil. I stand corrected on the size of the Jet live center. You saved me from ordering the wrong thing. (I went out and measured the thing to be sure.)
I already have an MSC order building because of another item I could only find there, so MSC it is.
I got to looking to find a definition of each kind of tap. I have a whole set that I have used for years and had no idea there were more than two kinds - "regular" and bottom." Shows what I don't know. :)
A taper tap has 8-10 tapered threads and is used as the 1st tap used in tapping a blind hole.
A plug tap has 3-5 tapered threads and is used as the 2nd tap in tapping a blind hole. Plug taps can be used in place of taper taps.
A bottom tap has 1 to 1-1/2 tapered threads and is used to tap to the bottom of a blind hole. It is the last tap in the sequence for blind holes.
Courtesy of toolingu.com.
I will get the plug taps. Sounds like a reasonable compromise for what I have in mind, given the diameter of the holes.
