locust box
locust box
locust box
keith zimmerman, Normal IL
>Recently, I turned this box from locust. It is approximately 3" high and 3" in diameter. The finish is one coat of Waterlox. The box was hollowed using a #3 Hunter.
Thanks for looking.
keithz
Re: locust box
inside
Re: locust box
Mike Stafford
Re: inside
Mike Stafford
>Looking good, Keith. How was that locust to hollow with the Hunter? If locust is as hard as I remember the Hunter tool was the right choice.
Re: locust box
Re: inside
Gary Evans Tallassee, TN
>Hi Mike,
Keith's locust is honey locust. My experience is that honey locust is much softer than its evil cousin, black locust. Honey locust is some pretty stuff, though.
Very nice box, Keith. I like your shape.
Gary
Re: locust box
Re: inside
>>...My experience is that honey locust is much
Gary,
The honey locust I got from you does seem softer than black locust I've turned, but it has hard spot throughout, almost like veins. These veins are darker color as well, creating interesting figure. However, the harder places provided more challenge on the end grain items I've turned so far. Some tools, especially gouges, decided to let the wood bounce them around for an irregular cut. A sharp skew chisel was assertive enough to cut clean.
Re: locust box
Re: hmmmmmm
Bob Jensen
>Looks exactly like the one i have here, oh wait it is that one. Right now Keith it is here on a display shelf with things other well known visitors have made in my shop its sitting with a Andi Wolfe, a Trent Bosch, a Cindy Drozda, and several Mn. woodturner club members pieces.
bob
Re: locust box
Re: inside
>Thanks Mike, The Locust was very easy to cut with the Hunter. In fact, the reason I turned this box in the first place was to try out a new version on the Hunter #3.
I had the privilege of trying these tools that have a swan neck radius, a half-radius and a full-radius. The only difference in them was the radius with the cutter angle being the same. I was impressed with them, but found them to be quite different. The full-radius tool was very aggressive, whereas the half-radius was less so. I found that I like the half-radius the best as it is more controllable for me. Don't get me wrong, both tools are controllable, but the half seemed to work best for me. Others might find the full more to their liking.
I am not affiliated with Hunter tools, I just like them.
keithz
Re: locust box
Re: hmmmmmm
>Bob, I am honored to be in such company.
Thank you
keith
Re: locust box
Mike Stafford
Re: inside
Mike Stafford
>Keith, I also use Hunter tools. It has been my experience that they are best suited to fine clean up and shaping work after the rough hollowing has been done with a gouge. I can remove the bulk of the wood much faster with the gouge but I like the quality of cut that I obtain using the Hunter for finishing.
I haven't posted a box in quite a while that didn't involve a Hunter tool.
I am not affiliated with Hunter tools either but I do like to use them.
Re: locust box
Re: inside
>Mike, I usually use the same process when hollowing boxes...for the same reasons; it was just faster to hollow with a gouge. I found that these new radiused cutters were just as fast as a gouge when hollowing this box. I did all the hollowing on this box with them, even removing the nib in the center. I was really impressed.
keith
