A SKEW WHIFF TALE. OT
gtwilkins
>I just read this story, oh so true!
http://home.vicnet.net.au/~pwguild/a-skew.htm
Enjoy, Trevor
gtwilkins
Enjoy, Trevor
I got a giggle with my morning coffee. Thx 4 post.
steve antonucci
Re: A SKEW WHIFF TALE. OT
Bob Macgregor
>I figured it was something like that.
the article mentioned invention of the wheel; here are two short history lessons on that (you probably never knew the wheel was so versatile):
http://veryfunnyads.com/ (enter search term "volvic wheel")
and
http://www.collegehumor.com/video:1800315
charlie belden
>I really don't know why such a mystique has developed about the skew. While a straight edged skew is a little tricky to learn to use, it's easy enough to grind or sand a slight curve to the cutting edge. Then it's easy to use the "sweet spot" which is actually about 2/3rds of the cutting edge, without worrying too much about catching the long point or the heel of the cutting edge.
And with a skew and a little experimentation you can get that sucker to cut beads and even coves like a spindle gouge, shape bowls like a bowl gouge can do, hollow straight inside boxes, end grain at the bottom of a box like a scraoer and peel like nothing else.
