Barracuda Chuck Problem
Martin Harris
Martin Harris
>My Barracuda Chuck (CSC3000C) is 6 months old. Today it has locked up after some turning; I am unable to move the jaws with the wrench. The jaws seemed fine when I chucked the turning, which is relatively small and light. I am using a Jet Mini.
I didn't use any CA glue on it :-)
Any suggestions on how to free it?
Thanks
Re: Barracuda Chuck Problem
robo hippy
>I have had my chuck jaws lock up on me (Vicmarc), The problem was broken pinion gear twice (the one you stick the key/hex wrench into), and broken main gear once. I could feel that something was wrong before, and could free it up by going to the other key and trying there. Eventually it did lock up and I got new parts. You may have to take it apart to see what is binding.
robo hippy
Bill McWhirter
>On my Barracuda csc3000, each pinion gear is held in with a small screw that comes in from the back of chuck. Perhaps if you remove the screws, you can get the pinion gears out and find out the cause of the problems. Be careful, they are small and easy to lose. I have to retighten them occasionally. Hope that this helps.
>There was a thread on stuck chucks a few months ago.
Could your chuck have been overstressed? Was there perhaps a big catch the last time it was used?
I bought a chuck from a gentleman who must have applied herculean force inappropriate for the strength of the materials. The chuck body was warped such that at one position the jaw slides would not. In my case the warping was evident by a slight but visible distortion in the face of the chuck body at the edges of the machined slide grooves. I had to disassemble the chuck and spend some hours of rework to fix it.
If not that, did you tighten while hot and now it's cold, or vice versa? Could some foreign object have worked it's way into the chuck? Any chance of a practical joker running amok in the house with your bottle of CA glue?
Martin Harris
Martin Harris
>Many thanks for all the suggestions and comments.
I don't have a compressor so got a can of Dust Off. That with some delicate hammering worked. Add some silicon and it's like new!
This site is amazing. Wish I had this level of support when I was in IT - might still be there.
Thanks again,
Martin
