Four Plumwood Turnings
charlie belden
>A neighbor did some major pruning of a plum tree in his back yard and knows I'm into woodturning. He brought over some branches about 4" in diameter for me to play with. Normally I don't turn green wood because I prefer doing lidded boxes and detailed finials. But the stuff was free - and it had some interesting color to the heartwood - so I turned some pieces out of it.. Roughed to round and then down to some heartwood, followed by initial shaping and hollowing through a 5/8" diameter hole (OK, so on one of them I hollowed through a larger hole in the bottom and plugged it afterwards. NOT a good idea with green wood turnings due to changes in shape when drying).
Being somewhat impatient, I then microwaved each and turned to final shape and wall thickness, sanded, oiled with Mahoney Walnut Oil to pop the grain and polished with HUT Wax on a buffer using an unstitched cloth wheel. None of the pieces were completely dry , but as I've admitted, I'm not very patient.
Three of the pieces are "pinch neck" forms and very rakuesque. The fourth I turned to allow for some carving and grinding and took the Proxxon little disk sander to it. Will be playing with that some more in the future.
Still haven't figured out a way of holding these things in order to turn a finished bottom.
Like most fruitwoods, plumwood is prone to cracking and splitting as it dries. I've found that the thinner the walls the less splitting and cracking there is. Also found that if you drill out the pith and plug it with either the same wood or a dry hardwood, the cracking off the pith is reduced or eliminated.
Comments, constructive criticism and suggestions will be appreciated.
charlie belden
Re: Four Plumwood Turnings
Steven Antonucci
Those all look very nice!
steve antonucci
>As far as turning the bottoms, you can make a long "rod" with a pad on it. The vessel gets the rod inside on the floor, and the tailstock goes up against the tenon.
There have been pictures, but I don't have one.
Sorry, Charlie. (Only the best tuna can be chicken of the sea...)
Steven
Re: Charlie, those are Awesome!!
Allen Neighbors
>I love those SW forms... wood's pretty awesome, too!
Here's a shot of one of my HF jam chucks. I have one that's a much sharper point, also. You can make several, but a couple have done me well.
The cone's tenon fits in the chuck. The padded end of the rod goes into the HF against the bottom, and slides through the cone and spindle, til the HF opening fits the cone. Then tighten the set screw (knob). Bring up the tailstock, and finish the bottom. Sand the nub by hand.
Good job on those forms!
Re: Those all look very nice!
charlie belden
>Steve:
I could put the drill chuck holding a dowel on the drive end to hold the pot from inside - but - it and a pad on the end would have to fit througha 5/8" hole in the top AND come back out. The other potential problem is that the bottom of the inside has that little raised pip area in the center. The pip is hard to get rid off inside a piece, but trying to turn it off blind and through a small hole is beyond my abilities.
I'm thinking some sort of jam chuck, maybe with some padding to protect the outside of the piece, and a center on the tail stock end could do the trick. Use duct / duck tape to hold the piece in the jam chuck to finiish off the center of the bottom. The potential problem with this solution is that these things are thin walled - and in some areas really thin (I'm still learning to turn blind). A little compressive force and one of those thin spots could go. DO NOT want that to happen.
Then again, this "challenge" needs a solution and I've got more of this plumwood. Worst case I'll be out an hour or so. Best case I've got another trick in my small bag of tricks.
Fun this woodturning thing.
Re: Charlie, the rod on mine is...
Allen Neighbors
>3/8" and the pad will easily fit through a 5/8" opening... that's the size opening I have on most of my hollowforms.
But, the cone has to be small point, also, and my other one is. I drilled the hole for the rod, and then tapered the cone to the hole, so the cone point will also fit in the opening. Just enough pressure to hold the HF centered is all you need in the opening. This type of jam chuck really does work well on HF with small openings. I used to use a donut chuck with a hollow (concave 'vee') turned in the center. But it was too heavy to mess with, and like you said, puts too much pressure on thin pieces.
charlie belden
>Leather! Perfect thin padding. That may be the solution. Half inch dowel with 1/8" space around it - two layers of thin leather on the end of the dowel but only two times the thickness around the dowel. Gonna have to try that - but with a drill chuck in the drive end.
Thanks.
Regarding the forms - spent a lot of time at Raku parties ceramicist friends had often. Did you know that drinking wine will keep smoke from making your eyes water? That's my story and I'm sticking to it.
charlie belden
GaryG in MD
>Allen,
I agree with you that these are very nice forms, but I wouldn't call them "SW forms". The front and mid left ones are what is currently being called "bag-o-sand". The back one is quite unique, to me anyway (and I'd like to see more of it, Charlie). The mid-right I would call an oval (Ellsworth style).
For some typical SW forms, take a look, for example, at Paul Porter's wonderful galleries at www.paulporterwoodturning.com .
Here's an 11" "SW" open-form I roughed out from a hunk of maple when I returned home from New Mexico last fall with visions of many beautiful Native pots still in my head. (No comments, please, on the horrid photo -- it was a quick snap for my record keeping and was supposed to be for "internal" use only -- it is presented here merely for the general shape.) I haven't finish turned it yet.
Cheers, Gary
