>It does look like it it set up for out board turning.
Wonder if you can add bed extensions? Does not look like the other end is milled to receive them. That would be a short coming. Many people turning spindles would like to be able to turn a 30" table leg.
Does it reverse? That would be nice for sanding.
And does the head stock pivot or rotate? Doesn't look like it. Seems like a couple of small things would have really taken it up a notch.
>Strange and unique design. The tool post is on the right of the banjo. It prevents the tool rest getting close to the work when hollowing bowls. I can't figure out what is the advantage of doing so. Other than that the specification looks good on paper. The outboard (if it works) is gravy.
Jet is coming out with the electronic VS version of the 1220. The slowest speed is going to be 270. That is a big advantage over their non-VS.
>I'm new to this forum so this might have appeared here before, but I didn't see anything in a search.
This is the new $1295 bench top bowl lathe from Vega. I have the model it replaced and love it. This model add the removable tail stock and a 1.25" spindle... and maybe more.
>on the head stock? Does this imply a VFD quality or DC drive? If so that would suggest decent torque at the low end? Or maybe it is just a simple digital tacometer? It is 110V input so it may be the same technology as the Jet Mini VS with torque limitations.
>I had an opportunity to turn a hollow form on the prototype for this lathe last fall and it had the makings of being a very good lathe. I really like the swing on this and the footprint makes it very usable in a small shop.
In regards to the 2413B Vega lathe; what kind of base was the lathe attached to? As I mentioned, I have the model 24 which is very similar except for the tail stock. I haven't had any good ideas for a stand that didn't take up a lot of floor space that I don't have. Currently, I have a base made from 2x4's that I clamp to my heavy work bench. It works, but I'm sure there is a better solution.
>Here is a link to the 25-200. General has just released an upgraded model with headstock indexing and shaft locking. The general costs more but does go on sale and has a swivelling headstock. the motors look the same, from what I can see in the photos.
I am sooooo pleased with the performance of the one that I bought a year ago. ET
