What do you use your compressor for?
Jim K in Trappe, PA
>I am thinking about buying one for hollow forms. I would also likely use it for an occasional very small trim/furniture nailgun project (not replacing a roof! Maybe 10 or 20 nails at a time).
My thought is a pancake compressor would suffice.
My workshop is in my basement, and the compressor would also be in the basement, probably in the same room, so I am looking for a super quiet model (maybe sil-air, although they are really pricey).
The big question is what size, because I don't think I need a big one, but then again....
So what do you use your compressor for? What size is it? Is it big enough?
Thanks,
Jim
Re: What do you use your compressor for?
>I have three. My "everyday" compressor is an old Sears (Emerson) compressor that has about a five gallon tank. It cuts in at 80 and out at about 110PSI. It sits in a little closet on the exterior of my shop, so the noise is not an issue. I have a bigger simair compressor that I do not use, but I bought it used for next to nothing. It has some sort of leak that I have not tracked down. Its my life insurance policy on its little brother. When the smaller one dies, I will fix the bigger one.
I also have a 1 Gallon Campbell Hausfeld I bought at Harbor Freight. Its very small and very noisy. I use it to carry out to where ever I need to drive a few nails. Works fine for that and did I mention its really noisy?
There is a review here on either turning or Messages of a Makita small compressor. That looked like it was much better than my little one and received good reviews and it was mentioned several times that it was much quieter than its predecessor.
Go over to messages and search for "out of the box" by Virgil Johnson on Feb 1, 2008. Among the messages are several compliments on the compressor and the place they bought it.
I use mine to drive nails and staples and wish it cut in at 90 instead of 80 PSI. Also for blowing the stuff out of hollow forms and blowing the dust off things I am sanding. Blowing up tires. Blowing crud out of motors and other places it does not belong. And many other things that will occur to you after you have one.
(I Don't have a Makita compressor and have never seen one, so this is really a second had endorsement. I have several Makita tools and like all of them. I would not buy another noisy compressor.)
Steven Antonucci
How I ever lived without one is a mystery!
steve antonucci
>If you turn hollowforms, blowing shavings is worth the price of the compressor.
Blowing dust and shavings off of everything (then go outside while the dust settles...)
I bought a cheap ($15) right angle air tool that I use for sanding on the lathe.
Blowing things up, of course. Beach balls and swim tubes for the kids, but I use the shop vac exhaust for the swimming pool.
Mine is pretty big (26G) and came from Lowes. I like the fact that it only runs once in a while, but it's noisy when it does. I think it was about $180.
Steven
George Balock
Re: How I ever lived without one is a mystery!
George Balock
>Jim,
I had a PC Pancake Compressor that I used for exactly the type of stuff you describe. It was one of the two gallon oilless type. It died after about three years of what i thought was infrequent use. I replaced it with a DeWalt oil lubricated one that is almost good enough for what I want to do (run a 1/4" die grinder). I believe that buying the oil lubricated compressor is the way to go. It wil run a long time, is quieter and wsn't that much more money.
Just My 2 cents.
George
Re: What do you use your compressor for? *LINK*
georgetroy
>I use the Hitachi EC12 portable air compressor mine is at least 4 years old now. It's great for hollow turning and to drive nail & staple air tools. Not quite, but it is not in the same room when I turn. I have 100ft of air hose. You need it for a lot of things besides turning, like airing tires and blowing off dust.
Hitachi
Bill Hale / The Wood Spinner
>Consider buying a small storage building to put outside for the compressor. Your vac can go in there also. Just pipe to the basement with hard pipe and go to the outlets from there. Use a shore piece of rubber pipe from the compressor to the hard line to cut down on vibration.
Buy about a 26 gal size. You will be happy to have one and wonder how you got along without it.
Bill in CG, AZ.
>I have a small 20 gallon single stage noise maker from Harbour Freight. I use it to blow out hollow forms and spray finishes. I thought I would use it for sanding but it runs constantly and is simply too noisy for that. I did get a small brad nailer sort of by accident. I didn't really think I would use it but I'm surprised how often I do. It works great for that.
What I really need is a 60 gallon dual stage unit but that isn't going to happen until I have a place to put it.
everything
>I've been using a Porter-Cable pancake compressor (labeled "Jetstream" on the side") for maybe 7 years now. It gets use nearly every day, at the lathe, outside of the garage with a long hose on a reel, with a small sand blaster, and with a variety of rotary air tools. I use it with a pneumatic stapler, finish nailer, and a framing nailer. This little compressor has plenty of punch to drive a heavy-duty framing nailer - we covered a building with rough oak b&b siding a few years ago and I've used it many times in and around the barn building horse stalls, tack room, etc.
I think the keys to keeping one of these healthy are:
- drain the tank regularly
- don't use too long an extension cord
- let the compressor rest a bit during heavy use
Running a compressor on a long extension cord will reduce voltage and the motor life. If I need to run it a long way from the house wiring, I use 12ga extension cords and cover most of the distance with long hoses. (The extra hose length also adds volume and acts like you have a bigger tank.)
It's not very quiet, but I suppose it could be put into an insulated wooden box. I prefer keeping the compressor outside the shop - I put a larger compressor outside in a separate storage room in my last shop and plumbed air lines into the shop with iron pipe.
Dick Hines
Dick Hines
>Get the biggest one you can afford. I am on my second one, the first being a pan cake type. The next one I get will be bigger jet. I want to run air tools with out the compresser running all the time. Being able to use a sand blaster would be nice too.
As far as noise, all oiless compressers are loud. At least all I have been around were. If you can find a place you can install sound proofing would be a big improvement.
Re: everything
Bill Crommett
>I am using a grand daddy of a piston compressor that I bought second hand from a Sears store 26 years ago. I used it for building the new house 18 years ago and when it started making funny noises I bought a five gallon C-H that turned out to be so noisy that I put it out in the barn to inflate tires and use for sand blasting. Then I resurrected the old timer to use until it quit, but it never has. It is quiet (being a piston pump rather than a diaphragm pump) Neither of them are of a capacity to use for much sanding or chiseling, and I am presently on the look-out for a bigger compressor, but I am dismayed by how few of the specs will tell if it is a piston or diaphragm, and I will not have another noise maker again. I am too deaf to damage my hearing any further.
Jim Miles- Charlotte NC
>Alternate idea: I have a old, cheap, from Goodwill, about ($5 - $10) vacum cleaner I keep hung behind the lathe to vacum out hollow forms and such. Also have compressor but don't use very much.
If You Want Quiet, Think Big!
Barry Turner
>I went through the same line of reasoning before I bought my compressor a couple of years ago. I use mine mostly for clearing wood shavings from my lathe and from hollow forms and blowing shavings along the floor like I would with a broom. I also wanted the capability to spray finishes and run a brad and nail gun.
You say you want a quiet air compressor, and then you say you are considering a "pancake". I have to say that pancakes are usually not quiet units. There are few, if any, truly quiet air compressors. Most pancakes are very noisy and cycle on very frequently because of their small tanks.
My solution was to get a large upright, a Husky 6.5 HP? (so they say, but I don't believe 'em!) with a 60 gallon tank. With my usual type of usage........ie. blowing shavings.......it only cycles on once or twice in a day of turning, sometimes not at all. How's that for quiet?
Dave Peebles Lyons, Ohio!
>Hi Jim,
I use mine for many things too. It is great for hollow forms, both for clearing shavings and blowing out the grain between sanding grits.
I also use it for the day to day tasks like, tire inflation and cleaning gunk out of the chainsaw after a long day of cutting.
I got this one from my father in law. It is oil less screaming beast that would drive you out of the room if it were in the room. I put mine outside the shop area where it is a least tolerable. To me it is third only to a dental drill and a router going full blast as far as noise goes. :)
But I would not be without one. My next will be a nice two stage compressor. They are much quieter... but much more $$$$.
One thing I have found when needing to drive a few brads at a remote location, a portable air tank will drive a ton of small brad for trim work and such. I do this very often. So a small compressor may work just fine for you.
Dave
John Scheideman
>After going through several compressors over the years I finally spent the bucks for an Ingersol Rand 60 gal. compressor and have been very happy with it. It is quiet, easy to drain, doesn't come on nearly as often, delivers lots of air,and is built to last. I bought this one from a compressor company so I knew it was an industrial model rather than the cheaper box store types. They are expensive but so worth it! I use it for everything....including spraying and painting. The disadvantage is that it is not portable. I also bought a really cheap ($45) one gallon compressor at Target which I hung under my lathe for blowing chips out of hollow forms. It is slow to fill with air but I realized that I would get what I paid for and it does work for the intended purpose and I can easily take it anywhere that I need a small amount of air.
One other thing....oiless may be less fuss but they are really noisy and don't last as long as the oil models. Do a thorough search before you buy and go as large as you can afford or have room for....you will find many uses for it that you didn't realize!
John
Don Orr
>Let's see, where to start.
Blowing up my wife's exercise ball, blowing up an Airbed for visitors.
Finish and brad nailers.
Cleaning the shop-I open both doors and blow the dust out when the weather is nice.
Cleaning chips out of hollow forms.
Putting air in tires.
Air ratchet, die grinder.
Air brush.
Probably more too. I like my compressor !
eliot d
>About the only thing I can add to these posts is that Harbor Freight sells a really inexpensive kit that automatically drains the compressor after each use. I think you're still supposed to drain it once in a while the usual way, anyway, but not nearly as much. Also, I have to admit, it's not so easy to install. But if you can figure it out, it saves a lot of time.
You may also want to find Andi Wolfe's message not long ago about her purchase of a SilAir.
no compressor in basement shop
robert davis
Thanks all! Good Advise. A lot to consider
Jim K in Trappe, PA
Barry, You can change those settings
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>All you need to do is take the top off of the pressure switch, and tighten the nut over the spring a little. This will raise the on / off a little.
I know there are likely to be a lot of fear of explosion post to warn against this. Just keep in mind that there is a blow-out release on all compressors to prevent this, and if you set it too high, it will release the pressure before anything explodes.
Virgil Johnson
>I just bought a Makita MAC 2400 "hot dog" style compressor. It is very quiet and looks to be engineered very well. It will produce 140 psi in a few minutes and has approx 20 second recovery. 246.00 from Tyler Tool. Stores under my jointer infeed table nicely. My uses are brad nailer and pumping up tires, etc.
Chet Bisno
>I've had my 4.5 CFM, 20 Gal tank compressor for 20 years. It wasn't until I got into turning that I used it frequently. I too make significant use of pneumatic tools. Harbor Freight has a great selection at good prices. And you can almost always find what you want in their sales flyers.
I'm going to upgrade to a 60 gallon this month so I can run tools without the constant racket of my oilless compressor. My compressor is in the garage with air piped to my basement shop. That would be OK if the darn thing didn't occasionaly recharge at night and scare the hell out of my wife.
I've noticed reduced noise from my vacuum cleaneer since I built a box around it with 2' x 4' acoustic tiles. But my compressor stays in the garage.
