Vacuum and pressure treating
Bill Hale / The Wood Spinner
>Ok the logical next question is after the chamber is done what is best to use to treat the wood and how to do it?
There will be a drain in the chamber for either moisture or chemical.
I plan on double valves so I can have the first valve open to allow liquid to drain into a chamber. Close the first valve and open the second to drain out and not lose vacuum.
Any other thoughts will be appreciated. I consider this project a work in progress by all of us.
Thanks Bill in CG, AZ.
Re: Vacuum and pressure treating
Gary Evans Tallassee, TN
>Hi Bill,
Admittedly, I don't know much about this subject, though I am curious about it myself.
I was told by a knife-maker who tried some rudimentary stabilization that the product he used was made for preserving items for museums. I don't know the name, but I know it comes in flake form and you dissolve it in acetone for use in the vacuum chamber.
Gary
Duane C.Leach
>You might try a type of johny lock or J air lock like the one used under the sink. This would allow constant liquid drain to drain and collect the liquid. And also protect the vacum source from that liquid.
Duane
eaglesc
>You will need a second vessel inside your chamber.
One to hold the vacuum the other to hold the piece you are stabilizing in solution.
