REAL MILK PAINT
Cut through the side, darnit
>Or at least I think that's what I said. My dog was looking for cover. I was trying to hollow a small Mesquite hollow form and made the inside bigger than the outside. I seem to be doing that a lot lately. I guess I'm working too fast and trying to do 3 things at once. Consequently I'm going to take a break. It was obviously the most perfect form ever created because you never screw up a crummy piece of wood.
Re: Cut through the side, darnit
Mike Stafford
Mike Stafford
>John, that only happens to me when I am almost done with whatever I am turning. I get so wrapped up in making that last smoothing cut that I hear a crack followed by bad words. Invariably for me it is a loss of concentration and attempting to make it too perfect.
Allen Neighbors
>Sorry, John.
You know? I think it must be written somewhere that you just can't ruin sorry wood... only wonderful wood.
Dick Hines
Dick Hines
>Man. I hate that when it happens. But I have been there and done that.
Never thru the side; always thru the bottom.
adrien
Barry Turner
>Hmmmm.........you made the inside larger than the outside? Don't think I've heard that one before.
When I went through the bottom of a small cherry bowl a few months ago, I told Joyce "I just ran out of wood!" I was turning about a dozen small cherry bowls from 2" thick stock and got hold of a blank that was less than 2" thick. So, I didn't poke through the bottom, "I ran out of wood".
It would be interesting to hear of all the euphemisms woodturners have fabricated over the years to avoid having to say, "I screwed up".
Jim Rutten
>I was in a class class at Arrowmont. First time ever I had turned bowls with a recess instead of a tenon. The first one I did I went clean through the bottom. The second one I had the instructor come over and check to see if I was getting too thin. He held it up to the light and sure enough the dimple for the live center you could see light through. Not to be defeated and since the bowls were approximately the same size I glued them together, cleaned them up, turned a lid for them. Instant hollow form.
eliot d
>I turn hollow forms mostly using a laser system. About the only times I manage to cut through the side is when, somehow , the laser shifts a bit (to the right) relative to the cutting edge. Then, you think the cutting edge is where it should be; but it's already going through the side! What I did to minimize this possibility was to shell out for a really good Oneway laser holder. These don't tend to wander.
