Vacuum chamber
Vacuum chamber
Vacuum chamber
Bill Hale / The Wood Spinner
>If the below formula is true, does that equate to 12.77 PSI on the outside of a chamber with 26" of vacuum?
1 PSI=2.036"Hg (inches of mercury)
My pipe is 20 " Dia. and 30 " long. I will be welding a plate on one end and having another plate milled with a lip so I can use an O ring and drop it into and on the other end. The vacuum will hold it in place. My question is how thick to make the end plates ? I am thinking 1/2 " for the top lid as it will be milled.
Thanks for the help
Bill in CG, AZ.
Re: Vacuum chamber
Re: Vacuum chamber
Jerry Bennett
>That will work
Re: Vacuum chamber
Re: Vacuum chamber
Bill Turpin in WNC mountains
>The pressure on the outside will be 14.7 psi at sea level. It is the difference between that and the lack of pressure on the vacuum side that crushes.
Re: Vacuum chamber
Re: Vacuum chamber
eaglesc
>Sounds like over kill, I have used 3/8ths plexiglass on a 1 gallon pickle jar.
As long as it is flat with a gusset less should do.
Re: Vacuum chamber
Re: Vacuum chamber
Steve Worcester
>If it is metal, 1/2" would be great. 1" MDF would work though too if sealed properly. But if it is for wood drying, metal definately.
Steve Worcester
www.turningwood.com
Re: Vacuum chamber
That sounds right to me
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>The area of a 20" circle is 314" X 12,77 psi = 4009 lbs. pressure on the ends. You can use thinner material if it is domed, but if that means extra leg work, it would be easier to just go for the thicker. I don't know what the minimum thickness would be for this, but I don't think you need to worry about 1/2" failing.
Sounds like you are going for it. I hope you will keep us informed as you proceed. Have you been trying other things out to test it?
Re: Vacuum chamber
Re: Vacuum chamber
>Bill,
I have been thinking about this. I was wondering if you could use a piece of large plastic water pipe for the tube.
For the ends, I am nearly positive the 1/2" steel will work for the ends, but that is going to be heavy. How are you going to handle it? Don't drop it on your toe. I have not calculated the weight, but it seems you will want to have a hoist to handle it without straining something.
I saw a truck going down the road the other day with a huge paint pot of some type on it. Close to the size you are discussing. Had about ten clamps around it to hold the lid on, but it was meant for internal pressure. That lid was close to what you want. Might try looking into pressure vessels for paint.
Re: Vacuum chamber
I don't remember from your original post.
Gary Evans Tallassee, TN
>Hi Bill,
I can't remember if you were going to use this strictly for drying wood or if you were going to use it for stabilizing. If it's for the latter, my understanding is that you'll also need to be able to apply pressure as well as vacuum to what you have in the pot.
If it's for drying wood only then my understanding is that you'll need to add heat to the wood in order to make the process efficient. This necessity becomes complicated by the fact that vacuum is a near perfect insulator.
Gary
Re: Vacuum chamber
Re: Vacuum chamber
>The pipe was delivered yesterday and turn out to be 20" ID 43" long and has a wall thickness of 5/16. It is the kind of pipe that is a spiral welded. I am thinking of mounting it on a drum dolly so I can use it on it's side or standing up on end.
Wow is it heavy. Lucky I have the truck mount crane thing to move it.
Bill in CG, AZ.
Re: Vacuum chamber
Re: Vacuum chamber
Steve Worcester
>vacuum is easy to do, pressure is a whole different story. For pressure, just buy a big paint pressure pot as you said.
With vacuum, a weak vessel implodes and makes a mess, with pressure, the vessel explodes and makes a widow.
Steve Worcester
www.turningwood.com
