A55 Smoothing Plane
Filling wet wood cracks
Greg Singleton
>Hi All,
I have a wet hollow vessel with an 1/8" wall thickness that has a crack that is begging for inlace or brass filings. If I let the vessel dry it will warp so bad that I would not be able to return. Therefore, if I want to add inlace or brass I will need to apply it and perform the final turning while the vessel is still wet.
Would you have any advise on glues or procedure that might help or is this just going to be a game of luck?
Thanks!
Re: Filling wet wood cracks
Steven Antonucci
1/8" shouldn't warp much and dry in a day
steve antonucci
Allen Neighbors
>Greg, you say, "...wet hollow vessel...", so I'm not sure of the wood type. If it's some sort of root wood, it could warp like crazy, and quickly, too. You say it's 1/8" thick? I'd fill it using super glue and whatever else I wanted to use, brass or other... the moisture will accelerate the CA. If you've waited this long already, it may be too late to return. I'd sand with a powered sanding pad, off the lathe.
Oak will warp pretty much, and fast... I love to turn wet oak and watch it move when it's drying. I'd do wet oak the same way.
Greg Singleton
>Sorry I probably didn't provide enough detail. It had been a long hard day and it was late when I posted.
the vessel is ash crotch wood and has many different grain patterns within it. Allen, you are right, it will/did warp. However, I caught it and re-hydrated by submerging it in water. I verified that it is running true by putting it back on the lathe. The turning is being stored in a 2 1/2 gal bucket of water by the lathe.
I am leaning towards the CA (medium thickness) glue as suggested, but I am a little worried about the brittleness. I am thinking what will happen is that the crack filled with CA will remain very rigid and the rest of the vessel will warp around it.
It's an interesting experiment at this point which will probably turn out one ugly vase, but I will keep chugging and post a pic of what happens.
Thanks for the feedback.
Greg
Barbara Gill, Remlik VA
>It is a little late for this piece but they make flexible CA.
Ric Taylor
Ric Taylor
>Greg,
I would avoid using CA glue on wet wood because the moisture increases the possibility of causing the CA to crystallize, resulting in the frosted appearance that will ruin your piece. Also, the CA won't adhere as well (maybe not at all) to wet wood as it will to wood that is more dry.
Usually it is a better idea to fill the crack before you reduce the thickness of the wall as far as you have. The results are usually better if you fill the crack when the wood is still at least 1/4" if possible, then continue to thin the wall after the crack has been filled.
Sometimes the crack won't appear until after the wall is thin, then you just do the best you can and hope for the best.
Ric
Chet Bisno
>Allen: Could you expand on your response regarding root wood. Is green root wood more stable than green wood above the ground? My experience with green wood is it warps regardless of the source.
Warped root wood...
Allen Neighbors
>I'm not sure of the type of wood it was made from, but Gary placed a HollowForm in the Instant Gallery at TD's Gathering in Georgia in '05. It was turned from a root (Rhododendron???). The form had warped, caved in, became completely out of shape when it dried, and I thought it was beautiful. It was turned very thin, while wet, and allowed to dry and do it's thing. After seeing it, I wanted to do something of the sort.
I turned a couple of small pieces from green, wet Peach tree Root, that reacted the same way. The green peachtree above ground wood that I've turned didn't react the same way that the rootwood did. But I may have not turned it quite as thin as I did the root, also... it's been a while, so I'm not sure.
Now I don't know if all root wood reacts like that or not, but the root wood I've seen turned thin and green and allowed to dry, has warped more than normal above ground wood that I've turned. I know there's probably someone else around this forum that has more knowledge of this subject/phenomenon than I do.
I obtained some freshly sawn, green, Oak wood this morning. I got it blanked out today, and am going to finish sealing it in the morning. Then I'm going to turn a HF that is thinner than 1/8", and see if it will warp as much as the peach root. It may have to do with the size of the piece, combined with the thickness (thinner is better) that has to do with how much it warps, also. I think Gary's HF was probably as thin as 1/16".
Hope this explains what I was thinking about when I made that other post. :)
