French Polished Finish???
Jerry Klug
>I want to try mixing my own shellac for polished finish on the lathe. What is the amount of alcahol to mix for a 1 lb cut and what difference does it make for different oils? I have heard of using linseed and mineral oil. How do different qualities of denatured alcahol effect the finish?
Re: French Polished Finish???
Mike Jones, Redding, CA
>Here on Wood Central, See the menu to the left, highlight "Articles",
click on "Russ's Corner", then "Finishing Secrets", Shellac.
All you wanted to know and then some!
eliot d
>I can tell you that in a classic French polish oil is not really part of the polish; just a drop or so is used as the polish is applied to lubricate the application. Almost any oil will do. In fact, French polish is not necessarily a mixture of shellac and alcohol. French polish is really a method of application. One could, for example, use lacquer and lacquer thinner, instead.
