Help Sears 351. 217170
Gary Smyth
>OK, several years ago I bought a Craftsman (Chinese) 351.217170 lathe with 38" spindle length, 15" inboard and 20" outboard capability. Cast iron bed, 1 HP DC motor, MT2, 1x 8 TPI spindle and I paid , I believe, $280 for it�pretty close to � something comparable. It is variable speed 400-2000 rpm. For what I bought it for the item was, and is fine for occasional use except for the bearings and they�re driving me nuts. Sounds like marbles. Note: It has made the sound from the beginning and because I didn't believe what I heard way back when (1997) I checked out two same model number lathes at that time and all had the same slop. Anyway, I this past week called Sears about the lathe to see if there was a better motor/bearing assembly and sure enough, zippo--it's no longer offered in the configuration I have. What a surprise. No assembly is available, and the assembly for a motor and bearings if the current replacement is purchased will not fit in the old housing in the bed. The bearings are listed as STD315225 or 6202ZZ double shielded
Still the lathe is decent enough, even good, if I can just smooth out the motor sound and maybe (if I can find something better) with a new motor get some additional torque for bigger stock.
Here�s what I need help with. I know next to nothing about bearings. If I replace the marbley sounding Sears bearings with new bearings, will the new ones (say Timken or the like) work smoother or am I buying more of the same noise only newer?
Anyone ever had this lathe and done the surgery? Any suggestions as to how adding a new motor might be done? Making it pretty is not my concern, but safety is, with kids and animals about. I can do this if I knew what to ask for. Ideas please. I don�t need a new lathe just a decent tweak.
Re: Help Sears 351. 217170
tm
>Mine is a 351.217150
I bought the maint. plan when I purchased mine.
My main problem was repeated problems with the Reeves Drive.
Never had bearing problems.
You might try finding the name/number and email of a support technician from Colovos, the company who manufactures the lathe for Sears. If your lathe is less than a year old, it will also fall under their warranty, if not, he is still a good resource and a quicker source for parts than Sears and a great source of knowledge for how the lathe operates.
I still have mine and use it for longer spindlework but using it
takes too much of the fun out of turning.
Once I bought the Nova I use now there was no going back.
tm
Colovos
tm
>Colovos Company
4444 West Ohio St
Chicago, IL 60624-1036
Tel: (773) 533-4444
Web Site: www.colovos.com
Business Description:
Work Tools Importer & Whslr
NAICS Code/Description:
333512/Machine Tool (Metal Cutting Types) Manufacturing
Mark Strang
>Gary, the 6202zz bearings that you are having problems with are an inexpensive item that might even be able to be purchased at a NAPA auto parts house. They are easy to change out and if you are not handy they can be removed and replaced at any machine shop or electric motor repair shop for next to nothing. The only concern that I would have is that the other motors sounded the same when you tried them out years ago. It could be that the bearing fits in the endshield or on the shaft are too loose. In this case, if the problem is the shaft, the bearing could be held in place with some Loctite. If the endhield is oversize then it could be punched to yield the proper tightness. These are "fixes" that probably would work for the amount of time that you seem to use the lathe. There are other ways to fix these problems but the motor/lathe is not worth the expense for the kind of use it is getting.
The bearings that are in your motor should yield about 20,000 to 30,000 hours of life so I would not think that they are bad but rather that the fits are of the wrong size. The simple solution is to take the motor to a local small motor repair shop and have them
test run it to figure out what is wrong. I am assuming that you have
run the motor uncoupled to the lathe to see if in fact the noise is coming from the motor rather than from the headstock.
To sum it up: the problem is 99% either the bearings or the fits based on what you described.
Appreciate the help.
Gary Smyth
>Thanks. I contacted Colovos (Colovas)and they gave me the generic bearing numbers. Tech there helped confirm the noise. I didn't think about the headstock making the noise as it sounds like the bearings, but it could very well be the headstock. I'll find a small motor shop as that seems to be the ideal solution as they likely would be able to do the assessment better AND help determine if the problem can be cheaply handled. The bearings will run only about $25 and the wavy washer minimal. If it's the headstock,?. With 20000 hour or more life (I'm guessing I'm a mere 400 hours in) I have a way to go, but a less noisy lathe would make me use it more. Thanks for the suggestions as to where to look for the problem and a suggestion on where to buy the bearings.
Re: Appreciate the help. *LINK*
Darrell Feltmate
>Gary
Sorry in a sense to tell you this, but the problem is not the bearings. This lathe uses a gear to gear drive to move the spindle and the noise is from the gears. In an effort to remove the problem, Sears went to a Reeves drive and a new headstock for this lathe. That is why the configuration is no longer available. Changing the bearings will only give you new bearings, not silence. Why the gears do not mesh better is a mystery to me. I have the same lathe but changed headstocks ( a very long story).
Around the Woods
Thanks. Grrrrr
Gary Smyth
>I believe that you are correct. Gears it is. Just goes to show why you should never purchase the first version of anything. Welcome to the Microsoft school of selling. Ya know, I'm a patient man but you can't know how angry it makes me to find out that they knew of the problem and fixed it, but not so those who supported it in the beginning can purchase a fix.
I swear that there ought to be a national moratorium on Sears�s tools until they start to consider their customers. A bad tool gives poor value and in my view I'm so disappointed in the way this was handled. I guess deep down I know I got what I paid for and it could be a lot worse, but why not enable us to upgrade with a new headstock that mated with the older bed when they knew that the problem existed?
I knew better, but set myself up anyway. Still, I'm thinking they are crapheads!
