Kelton Hollowing Gate
Tom Minehan
>Does anyone use the Kelton Hollowing Gate while using the hollowers? I use the mini set and wonder if the gate is worthwhile.
Tom Minehan
Re: Kelton Hollowing Gate
Mike Jones, Redding, CA
>The Kelton Hollowing Gate is not COMPLETELY useless in my shop. I do recall one time when I felt that it kinda saved my bacon, but mostly I find another way to get done what it is supposed to help do.
It is heavily constucted (catalog pictures do not do it justice for size and heft) and although not heavy enough for use as a boat anchor, it would suffice as a door stop.
The saddle is not large enough to accept my (one inch diameter) Mega Eliminator, the deep hollowing tool of choice for me, and the saddle support pin extends through the arm to a degree that it interferes with small diameter openings.
The pin could be ground flush with the arm without sacrificing any strength, and perhaps some day I'll do that. It might help.
I'd be happy to swap mine for something of similar value.
Mike
Dick Hines
>I have an Iron's gate. It will work with all but the smallest Kelton tools. I use a Jamieson system most of the time, but I still free hand hollow some times.
Before you ask, no I don't remember where i got it. I have had it for years.
leppikallio
>I have something similar shopmade (Phil Irons gate meets Kelton gate :). Couldn't be much uglier but it really is great. I think it takes much of the stress away and also helps with leverage etc. Also I use it with my Termite (3/4" shank) and Munro hollower.
joaz
>You can have mine for a small fee. i had to cut about and inch off to fit my antique lathe's tool rest holder. I only used it once or twice and found it was fairly usless. let me know if you want it.
Tom Minehan
>Thanks for all of the replies. Joaz - I will pass on your offer but again thanks. I didn't have a good concept of the size of the hollower. My hollowing is mostly using the Kelton mini's through small openings so this sounds like it would be sending a man to do a boys job.
Re: Kelton Hollowing Gate *LINK*
Darrell Feltmate
>Is this any help? I have made some changes in my new one but the principle is sound. Besides, it only cost a couple of bucks and it is fun to try. Most of the time I use it with a hook tool but it is good with the hollowers for heavy roughing. For fine work I like to use a lot gentler cut and feel for the work more than the pivot allows.
Pivot for hollowing
