>The little pin that keys into the tail stock shaft keeps slipping down. I tap it back in, but now it comes out at the start of every new project. Any ideas? Replace it with a new one that is a press fit? Epoxy it in? Or??? Don't want to make it worse with a dumb fix.
>Hi Jerry. I had the same problem with my 3520A. I think it was a press fit when new.
I just mixed up a small wad of the plumber's epoxy (like chewing gum) and pressed it onto the pin. I didn't want to risk regular epoxy or CA winding up on the tailstock ram. It's been like that for several years. I haven't even thought about it until I read your post.
>Jerry I just had the same thing happen last week for the 3rd time in 4 years. Apparently what happens is the hole is very slightly tapered. When you put it back in with a gently tap it must enlarge the hole slightly. Then it happens again and you do the same. eventually the hole is enlarged to the point the pin hits the bottom of the groove and won't drive in far enough. I used some thin CA last time and obviously that didn't work.
Here's what to do. On the new 3520B they did away with that pin. I checked this weekend. What they did was add a setscrew on the backside of the tailstock with a locking nut.
The quill is rotated to the 9 oclock position looking from the inboard side. Then you drill and tap a hole in the back side of the tailstock about 3/8" from the inboard end. I didn't measure the setscrew but it looks to be about 10/32" Buy a setscrew that's long enough to stick out about 3/8" when full seated in the quill groove. Install a locking nut on this set screw and you've just modified it exactly like what they did at the factory to solve this problem.
I will probably make this mod on my machine this weekend so if you don't understand and need a photo just sit back and wait awhile. Based on todays forcast the thermometer will have changed 60 degrees or more by then.
>John, Great observation and idea. With my non existent metal working skills I would be deathly afraid of missing the mark when drilling into the side of the tail stock. Let me know how it goes. Why not just tap into the existing hole?
>Jerry I don't see why that wouldn't work. I haven't measured the hole. It is probably long enough you could just use a setscrew with some locktite and forget the locking nut.
>Howdy Jerry: I had the same problem two years ago while drilling out the center of a hollow form with a forstner bit. Pin dropped out, bit caught, and before I could turn the lathe off, the tailstock had screwed all the way out to the end and kept turning (it pushed the tailstock to the right in the process). Stripped out the screw assembly inside the tailstock. And, yes, I had the tailstsock tightened down well. I called PM and they told me that they had a bad run of tailstocks with oversized holes. They replaced mine and the new one hasn't moved a bit since I got it. You might call PM (you'll need original purchase info for warantee purposes) and see what they say. Ed
>which I did about 3 weeks ago, and so far so good. Simple and cheap. I guess this was a common 3520A problem and one of the older experienced employees recalled the fix. I used the Blue Locktite, strong but not permanent, so I could work the dowel out if I ever needed to. Thanks for your help and ideas.
