Corugatta burl bowl
Corugatta burl bowl
Corugatta burl bowl
stacey s
>This is a bowl made from corugatta burl. It is 100% natural on the bottom, ie. no chucking location. To do this I used a piece of 3/4" plywood and temporarly glued the burl to the plywood using wedges and hot melt glue. I was really suprised at how well the hot melt glue held. This burl is 13" x 11" x 4" thick. The finish is danish oil. I will buff it after the oil dries. Comments critques welcomed.
Stacey
Re: Corugatta burl bowl
Corugatta burl back view
stacey s
Ron in Drums PA
>Wonderful Job Stacey
Would you show us your pictures of your plywood setup?
plywood backboard
stacey s
>This is the plywood backboard mounted on a faceplate. It is 3/4" thick. I cut approx 1/4" deep grooves every inch to give the glue more bite.
burl mounted on backboard
stacey s
>Here is the burl glued to the backboard with wedges and hot melt glue ready to be put on the lathe
me turning the burl
stacey s
>Here is a picture of me at the lathe turning the burl in the pictures above.
Stacey
Re: me turning the burl
Carol in Illinois
>Ok. My official reaction is that you're nuts.
On the other hand, you could just be WAY more experienced than I am... which would not be at all hard to do, given I've been turning for all of 9 months and have turned a total of seven boxes or bowls.
In any case, this looks incredibly dangerous, and I can't believe you had the guts to even turn on the lathe with this arrangement. Many things look dangerous when you don't know how to do them, so maybe that's the case here.
Glad you survived the experience. Nice bowl, by the way.
Thanks Stacey
Ron in Drums PA
bowlman
>Stacey
Good to see you are still at it! My first experiences with burls was nearly 25 years ago and I struggled with the mounting. Do I mount with the top to the ehad stock, turn a recess and glue in a glue block? Sand the bottom smooth and then attach a waste block for the chuck. Many ideas came and went and none were satisfactory until I remembered the hot melt glue gun and the wooden wedges. Like you, that is how I have turned several hundred BLMB bowls ... now it looks like I need to try some of this corugatta stuff or some eucalypt burls.
Good job as always!!!!
dtewell at central illinois
>I would never have thought that hot melt glue would hold up that well. Something to stick in the back of my mind for later use.
Bill Hale / The Wood Spinner
>Stacey
I like your system. My only question is how do you get the hotmelt out of the rough side of the burl when finished?
Good turning and be safe
Bill in CG, AZ.
Mike Rubes, Apex, NC
>Hi Guys,
Like Bill, I would like to know about the "unmounting" and cleaning of the hot glue. I really like that natural effect and rough side of the back of the bowl, but it seems like the glue would seep into the cracks and be a bear to remove?
Thanks for any information,
Mike
Back at work in Apex, NC
stacey s
>Thanks Carol. I was very cautious when I first turned the lathe on. I started slow and stayed out of the way. One important thing to note is that the tail stock was against the piece almost the whole time I was turning. I only removed it at the very end to remove the numb that couldnt be removed any other way and then I made sure to take light cuts.
Stacey
stacey s
>Amazing as it is the glue did not get into the small holes on the back hardly at all. To remove the majority of the glue I just used my pocket knife to cut and pick at it. It comes of quite easily.
