>Been wanting to do some square turning for a while now. This is an ash platter which is about 12 inches square. It sits on an inverse tapered (narrower at top end) foot about one inch high by about 3 inches in diameter (not visible in this view).
>That's really nice Bruce. I love the simple lines and the elevation via the foot. Did you glue sacrificial strips to the sides to prevent chipping (and cut them off later)?
>... bandsawing off after turning is CHEATING!!! Do it the true and challanging way, and keep your fingers, knuckles, and all other body parts you hold dear BEHIND the tool rest! Well done Bruce.
>... carving on the lathe, and that's not cheating. But the Subjective Universal Laws of the Universe dictate that there are both good and not so good ways to accomplish a task. In the case of waste wood on a square turning, the waste pieces glued to end grain create a definite hazard should that weak joint fail, and I know that such a possibility has actually occurred- don't ask me how I know! I turn my square pieces in a variety of shapes and profiles, and rather thin as well, and you can't accurately determine if the edges are "perfectly" uniform when waste wood blocks your visual calipers. Besides, cheating diminishes the great feelings of satisfaction that you enjoy when you've finished a tricky square piece, knowing that you've cheated death once again! ;-))))
>Ya but cheating also helped get the Patriots to the Superbowl so how bad can it be? Ok, ok, ok.... Now all of you Pat's fans can just relax because I am kidding. Breathe deep now. Iiiinnnnn and ooouuuttt.... Doesn't that feel better?
Fair comment Jamie and I like the delivery. The few times I have tried square pieces the results have been less than satisfying. I haven't tried the 'cheating' method yet but, honestly, I probably will next time I go square. Just to try it out, naturally.
