200+ woodworking book reviews
another finishing question...
GaryG in MD
>There have been some very good comments on finishing recently, so I would like to add another variation.
I have turned a 6"-tall dogwood NE double-bullseye "cup" form and soaked it pretty well with 3 coats of Watco DO. This particular piece of dogwood is neither light nor dark -- it's a kind of light cherry color. My problem is that the bulls eyes are not very visible, all things considered. Now I know this isn't locust, and I shouldn't expect too much contrast, but I would like to see if I could get a little more accent.
So my question is: given that it already has three coats of thoroughly dry Watco, is there anything I can do to punch up the rings. I've thought of adding a colored wash, or colored oil or varnish, but my fear is that it will just darken the whole thing without adding any additional contrast.
I would enjoy hearing your thoughts. ...Gary
Re: another finishing question...
Mac
>Gary, You might try putting a gloss finish on it and then rubbing it back to whatever sheen you like.Sometimes bringing the gloss up will pop figure.Spray lacquer would do it,right out of the can....it is compatible with DRY Watco.Use the gloss one,let it dry well,longer the better,then steel wool it back to the amount of sheen you like.
GaryG in MD
>Thanks Mac; that's been my "fallback" position, but I thought I'd see if somebody might know a way to squeeze a little color in there before I did. The problem is that I'm not fond of real shiny NE work. ...Gary
