>Tonight we had a great deom at our turning cloub (Bucks Turners) by Tom Buchner on amongst other things the Sorby Texturing tool. I was looking at Tom's tool and noticed the the teeth on the geas were sharp. I asked if he had sharpeed them and he said no, that's the way they came. After coming home, I checked my Sorby tool and the teeth aren't sharp. Does anyone know if this makes a difference?
>You should have the video that came with the tool and it shows you how to lay it sideways on the grinder to sharpen the wheels. You want the wheel to spin as its being sharpened on the grinder wheel and with a light touch. If you don't have the video email sorby and ask them how exactly to do it. DonL
>Thats what you should be sharpening, the flat side (radial). I'd have to find my tape and double check before you grind up a good tool but if I remember correctly you lay the side of the wheel on the grinding wheel and give it a whiz and flip it over and do the other side the same way very fast because it looked like it didn't take much to put the edge back on. Looked simple enough to do but since I havn't tried to sharpen mine yet, who knows so hold your horses if you want me to look or contact Sorby and get the straight talk from them. Don L
>Okey I looked at the tape, what I told you is true but that is if you kind of damaged the tool like dropping it then you would use the grinder the way I said. Otherwise to refresh the edge you would have a round piece of stock mounted on your lathe and then you would stick your wheel straight into the wood to get the wheel rotating, the wheel will be vertical like a tire on a car as its put against the wood. Then with a diamond stick you hold it against the side of the teeth on your wheel at the same bevel that is on the wheel and that should refresh your teeth according to the instructions from Sorby and of course use your tool rest. Hope it helps , DonL
