antlers?
antlers?
antlers?
JohnKJordan in East TN
>I found these while horseback riding in the woods.
Anyone turn deer antlers? Are they hollow inside?
Re: antlers?
Re: antlers?
Jerry Bennett
>John, they are not hollow. They make great pens. The smell when turning is not pleasant. It looks good to leave a little "bark" exposed on a pen.
Re: antlers?
Re: antlers?
Dick Coers
>I have turned a few pens from antler. The are not hollow on the inside, but they are more porous. Kinda like cheap particle board. I use CA to fill them and the effect is really nice.
Re: antlers?
Re: antlers?
keith zimmerman, Normal, IL
>I have turned several pens from deer antler. Three hints I discovered while researching the process:
1. Periodically soak the blank in CA because the antler is very porous. The CA will strenthen the antler, allowing you to turn it.
2. Use a scraper to shape the pen. I found that a skew doesn't work very well.
3. Sand like wood, but finish with CA only. Use good ventalation while sanding.
Personally, I didn't have any problems with the 'aroma' while turning, but that doesn't mean others won't.
keithz
Re: antlers?
Or like teeth getting drilled at the dentist.
RonZ
Re: antlers?
Re: Or like teeth getting drilled at the dentist.
don lewonczyk
>John did you find the pair together? They don't usually come off in the same place at the same time, at least I never found a pair together unless the skull was with it and they were still attached.
DonL
Re: antlers?
found together
>don,
Yes, I found the two on the trail within 4 feet of each other. I was surprised, since I thought one would most likely come off before the other and be dropped somewhere over the ridge. One is 3 point and the other 4, but they otherwise look to be the same size, weight, color and texture, and I can believe they came from the same buck. I suppose two bucks could have joisted in that spot with each losing one, but I didn't notice any ground disturbance.
Judging from how clean the separations are and the fact that I rode on that same trail Saturday and didn't notice them, I suspect they were dropped very recently. The deer and I seem to use the same trails.
Re: antlers?
Antlers are bone.
Brian Hahn in SW Wisconsin
>Deer antlers are bone and they are porous inside. They turn and smell like bone.
Is that a typical pair for your region? I know deer are smaller in milder climates. I'd guess that they came from a 2 year old buck, although our northern whitetails usually sport more substantial racks at that age and our yearlings usually have spikes or simple forks.
Re: antlers?
Re: Antlers are bone.
don lewonczyk
>Im glad your talking about deer and not men! I guess if all you had to eat was acorns and cotton you would have a small rack. Not much corn, soybeans or wheat are grown around here. We had a lot of does die this summer from blue tongue and left a lot of orphan fawns. I started feeding the does that had 3 to 5 fawns sucking them and soon the fawns started eating the corn and now I have about 25 out by my storm shelter eating corn twice a day and at $6.50 a 50lb bag it adds up fast. It looks like a herd of goats out there, they let me get to 20 feet of them and one will snort and they run off 50 or so feet but come right back to eat when I walk away. DonL
Re: antlers?
Yes, the deer are relatively small around here. Bucks with large racks are rare - most that I see on my farm have 4-8 points.
Re: antlers?
Re: antlers?
eaglesc
>I turn a lot of antler.Though described as "boney" they are not bone.
I have turned pens where the blank contained part of the skull and there is a distinct difference in the density.
When turning pens the optimal size is one that has the "pith core" the same size as the tube.
If the porous section is revealed I sand with a slurry of CA and antler dust.
The results are like a "crystalline" surface
This is one that went to Sean Troy in last years turning exchange.
Whit tail antler inlaid with walnut maple and red accents
