Filling cracks?
Filling cracks?
Filling cracks?
Jim K in Trappe, PA
>Do you have any favorite tricks for filling cracks? I've heard about sanding with CA, sanding with BLO, etc, but haven't tried any techniques and would be interested in what works for you.
I turned a couple little hollow forms from unstable wet spalted wood, and got a few stress cracks as the wood dried, due to how uneven the wood moisture was. They started out big (1/32" - 1//16"), and then closed up when the drying caught up across the board, so now they are hairline cracks - not closed completely, but almost, and the wood seems to have stopped moving.
Thanks,
Jim.
Re: Filling cracks?
Re: Filling cracks?
>The thinset CA will flow into a crack and help stabilize it. DO NOT WET SAND CA! Wait until it dries. For larger cracks, I will use a clear epoxy and sometimes add filler (carbon black, key shavings, etc. [I'm too cheap for turquoise]).
A drying oil will fill pores and such but will not stabilize a crack - you don't have any significant bond strength.
My $0.02.
Re: Filling cracks?
Re: Filling cracks?
John Veerkamp
>I use ca glue with a variety of fillers. Save sanding dust of different colored woods, put thin ca into the crack and rub filler with your finger into the still wet ca. when dry sand to finish. I've also used finely ground coffee and brass key filings. Saving sanding dust from the same wood can make for an almost invisible repair, contrasting color filler can give interesting effects.
John
Re: Filling cracks?
Re: Filling cracks?
GaryG in MD
>John,
First, you have to decide if your goal is to highlight the crack as a feature or whether you want to try to hide it ("try to" being the key words). When you know the answer to that question, then you can move on to a set of potential solutions.
If you click the "message archive" link at the top of the main page, you will get a search window. Change the "any" to "all" and type "filling cracks" or "crack filling" into the box and hit return. You will get a large number of hits from past WC posts, including several major threads in which the problem is discussed in detail.
...Gary
