>Greeting All! I recently acquired a nice batch of apple wood, some of which has spalted already. I did a hollow form but really wasn't happy with the overall color. Apple is a particularly "blonde" wood. Although I knew better, I finished it with Danish Oil. The definition of the spalt lines blurred , as suspected. I was hoping to add a little deeper color to the light colored wood as Danish oil can do, albeit slight. My question is, how can you add a little color to spalted wood without ruining the spalt lines? Or should I simply accept the fact that when dealing with spalted wood, "It is what it is..."
>Eric, if you look closely as some of David Ellsworth's recent spalted hollow forms you'll see some definition in some of the shapes produced by the spalt lines. He carefully paints them in with artist brushes and he told me he used Waterlox. What this actually does is highlight some of the areas from the others.
Please clarity -- are you saying David paints the spalt lines themselves (with a very narrow brush) with Waterlox or that he paints an area bounded by certain spalt lines with Waterlox to give the whole area a slightly different tint than the rest? I think you're saying the latter, but I'm not sure.
>What I've done several times is to (first) seal the finished turning with a sanding sealer and let it dry completely. Then hand sand very lightly, but completely, with 400 grit.
(second) Make a mixture of wipe on poly and an oil stain of your choice. I've used MinWax red oak to get rid of the greenish-yellow cast that is common in spalted woods.
(third) Apply the stain/varnish mixture with a small piece of foam rubber or any lint-free applicator. Try to get a uniform application.
(fourth) Let it dry completely, which may take several days to be on the safe side.
(last) Go over the surface with fine steel wool and then cover the stain/varnish glaze with a topcoat. I've only used wipe on poly as a topcoat but other finishes may work.
This procedure lets you alter the color cast of the piece without degrading the definition of the spalt lines or having the wood soak up so much stain that the spalting is hidden and the piece ruined. Be aware, however, that your finished result will only be as good as the care you give in applying the sealer, sanding, and applying the stain/varnish mix. Good Luck!
