Ambrosia Silver Maple HF
Andy DiPietro
Andy DiPietro
>Hi Everyone,
I have been experimenting with shape and form on large vessels. This piece is Ambrosia Silver Maple and is 17 1/2" high x 11"dia x 3/16" wall and turned on the pith center. The collar has a 1 �� opening and the base is 2� dia.
I almost went through the bottom (1/32") so I backfilled with CA and sawdust. That could have been a really bad day or weekend. I applied 6 coats of Waterlox to give the finish depth. The white silvery chatoyance areas look like quilted figure but I do not know if that is the correct why to describe it. How would you describe that figure even though it is hard to see in the picture? Please comment on shape & form etc.
Thanks
Andy DiPietro
Re: Ambrosia Silver Maple HF
Andy DiPietro
PIC2 Top View
Andy DiPietro
Ron in Drums PA
>At first I thought you added a collar, then when I enlarged the image I realized it was part of the wood.
Ron in Drums PA
>Meant to say, great job on a great looking piece
Dale Cook
>I think the form on this piece is very nice. I also like doing large pieces like this, It's very challenging.Great piece!
George Van
>This is a very pleasing shape Andy, the 2" base is invisible! Before reading your description my question was to be "how do you get this to stand?"
Bill Hale / The Wood Spinner
>Andy
Realy nice piece and finish. Don't you just love it when it all comes together.
Good turning and be safe
Bill in CG, AZ.
Cyril Griesbach
>Andy, Nice wood and nice forms also. And...I don't know if I'm right or wrong, I call that kind of figure quilted too.
Dick Hines
Dick Hines
>Andy I love the pieces. Nice shape and figure in the wood. Here is the only thing I would do differently. It has nothing to do with the shape. When you put your finish on why don't you pore some finish inside and slush it around. It stop the contrast between the finished wood and the non finished wood.
I like to finish the insides of my HF's . Just my opinion and you know about them.
Very impressive
GaryG in MD
>Great form in such a large piece. Nice wood and finish. Love it. ...Gary
Turning centered on the pith
Dinyar Chavda
>Andy:
Quick question re the fact that it is turned including the pith. Do you hae any problems (or take any steps to prevent) cracking?
Andy DiPietro
Re: Turning centered on the pith
Andy DiPietro
>Hi Dinyar,
After I turn the piece between centers and form a tenion I CA glue the bottom. Then I mount it on a four jaw chuck. I worked on this piece for two days so I soaked in a bucket of water overnight and then finished it on the second day.
On the top side I center the pith and use a 1 3/4" opening for the collar. That size is usually large enough to remove the wood stresses. I occasionally spray the collar with water as I am hollowing so that it does not dry and crack on the lathe.
You also need to start with a recently felded tree or a waxed log where you cut off several inches off the ends to get green wood.
After I am finished hollowing I reverse the piece and finish the bottom. I then coat the bottom with CA glue. After that drys I coat the inside of the bottom by dribbling CA glue through the top collar.
I apply one coat of finish to the outside and let the pieces dry for 3 or 4 weeks before applying more finish coats. If you hollowed the bottom thin then you will still get a few small cracks that will need to be filled.
Hope this helps
Andy DiPietro
