Bill Grumbine bowl turning classes rock
wilbur
>I took a bowl turning class with Bill Grumbine this weekend. I went to the class with three things in mind that I wanted to improve with my bowl turning. He fixed six: the three things I wanted, and three things I didn't even know about. The best thing is that they were all little simple things that I could do, not some sort of arcane turning magic.
I would highly recommend taking a class with Bill if you get the chance.
Re: Bill Grumbine bowl turning classes rock
Gordon Seto
>I had his class the day after his demo for our BWWT Club. It was in a small group setting. It was not "follow the leader" kind of class; each proceeded at his own pace. You learn as much as you want to.
We usually got a lot of advices when we didn't know which end of the tools to hold. But after bringing several semi decent turnings with 60 grit gouges to the show and tell, the flow of advice stopped and you mostly hear are complementaries. You will have to hear between the lines to figure out what areas needed to be improved. If you only hear "nice wood", then you know that was a horrible piece.
Bill is an experienced teacher. Some advices on some little things that I thought I knew but didn't do well were priceless.
Don't let his DVD which is highly recommended for beginners fools you. His classes are not for beginners only. Even if you have couple bowls under your belts, you will still benefit from them. I highly recommend them also.
Gordon
One tip that made it all worthwhile
wilbur
>I thought I'd pass on a tip that I got in the class that has made turning much easier for me. This applies to both bowl and spindle turning.
Previously, when I would make a cut, I would stand in a comfortable position, bring the tool up, and move it to where I wanted it to go. Bill had me set up a cut in this manner:
1. Put my body in the position that I expected to finish the cut.
2. Put the tool in the position that I need to start the cut.
3. Lean my body over so that it supports the tool. I'll feel a little off balance, but that's okay.
4. Make the cut.
The advantage of this method is that since I already placed my body in a comfortable position to finish the cut, as the cut progresses, it gets easier because my body and arms are moving towards a comfortable position.
Before, I started in a comfortable position, and as I made the cut, I would find myself leaning and getting more off balance to finish the cut, so that the cut would get harder to do as it progressed.
This tip has made all my cuts easier to do.
