Bowl/chair part kiln...
Rob Hix - King George, VA
>Ok all you turners,
Do any of you use a bowl kiln (i.e. a box with light bulbs) for drying your bowls?
I am looking for some ideas on them for some projects that I have upcoming. The main thing I will be using mine for right now is super-drying the tenoned pieces of chairs, stool, foot stools etc. By super drying the tenons then finish turning them, when they are put into the chair/stool legs, the tenons swell back up and lock the joints.
Basically I would like to get some ideas. So, if you could post pictures or references to articles, I would greatly appreciate it.
Thanks in advance,
Rob Hix
P.S. If you use one, throw in your experience with a kiln schedule.
Re: Bowl/chair part kiln...
>I do chair parts.
For the hoops, legs, backs and spindles I use a plywood box that has the interior sheathed with "blue board" insulating foam. I have an old heater inside the box (this is going to change one of these days). There are cleats screwed to the inside of the blue board, into the plywood. I can put stretchers from one side to the other and vary the height as needed. Mostly it takes 2-3 days for the spindles (they are only 3/4" in diameter) and 3-4 days for the hoops, backs and legs (~1" thick or greater).
Walter uses an old chest freezer for his parts. He has two shielded light bulbs in his with a rotary dimmer switch. His drying takes a little longer.
>Thanks,
So from what I am gathering in my research, I can do my rough turning one Saturday and place my parts in the kiln. The next Saturday I should be able to take them out and finish turn them. My plan right now is for a simple cube about 24"x24"x36-40". This should take care of anything that I am planning on doing. Putting one or two bulbs in the box with a small fan should help things out.
Thanks again for the info. Now to start plans.
Rob Hix
Barry Turner
>Plan on having a substantial number of failures (cracks and warping). I dry my bowls a little slower than that. My bowl kiln is a paper grocery bag. Just my thoughts. Others may disagree. And probably will. :-)
>I have to agree with Barry. I don't use a kiln for my bowls but have used one for chair parts and I use the microwave for speeding up boxes. I would think drying bowls that fast is asking for problems. I haven't tried the alcohol drying that many have suggested but I think that might help of your going to dry them that fast.
By far the best thing to do is to rough turn whenever you can and put them up somewhere to dry. If you do this often enough you will always have one on the shelf that is dry and ready to go. My experience is slow and steady produces less problems than rapid drying.
>Barry and John,
I was not thinking of drying a bowl in a week. At the temperatures a box like that would produce I realize it will take a couple of months or more to dry a bowl like that. I also think I need to have a little more sophisticated kiln control that just a light switch. That would allow me to evacuate humidity as needed.
My example of one week was strictly for chair parts which would probably be made strictly from kiln dried lumber that is at EMC. Thanks for the warnings on the bowls though.
Rob Hix
Two Old Refrigerators...
Allen Neighbors
>Both are two-doors. One of them is a side-by-side, the other has the freezer on top.
I drilled about a dozen 1/2" holes: through the bottoms, through the tops, and through the separating walls.
In the side-by-side: I have a 40w bulb in freezer comp, and 60w bulb in the larger side. I also have a small fan in each side to circulate the air within the compartment.
I turn on the lamp and/or fan, intermittently (about 2 hours or so a day) for one week. Then I turn on the fan only for about 6-8 hours every day (when I'm in the shop), for one week. Then I turn on the lamp only, for one week. Then I turn on both, fan and lamp, for one week. By then most roughs are normally ready to re-turn.
In the other refer, I have a 60w bulb in the lower compartment, and nothing in the freezer comp. I use this box for blank storage 'til I can rough turn. I turn the bulb on about an hour per day, just enough to get the warm air to exit the top and bring in a little fresh from the bottom.
>When I build my next chair rail kiln I'm going to put a thermostat just like the one in my chemical cabinet. It keeps everything at 60 degrees but I don't see why I can't just get a different thermostat and set it at 100 or more for drying the chair rails. I just use a 60 watt bulb in my chemical cabinet. For the chair rails I would probably use 100. You can regulate the temperature pretty well on those by simple having an adjustable window in the top to let out some of the heat.
Re: Two Old Refrigerators...
Bill Crommett
>Remember that commercial kilns monitor the moisture content of the air closely and lower it slowly to prevent case hardening and cracking. The idea is to let the moisture out slow enough so that the inside will be very close to the outside as far as moisture content is concerned.
Allen Neighbors
>I guess that's why sometimes I gets it right, and sometimes I gets it wrong, Bill. :)
Bart Rhoads
>If you are going to go with a box type kiln, I would suggest to try to get a upright freezer. With a refrigerator you lose the space where the freezer is located. I have been using two of these for over 8 yrs. They are not fast but faster than a bag. Mine usually takes 3 1/2 weeks to dry a load. I can put around 30 to 40 pieces in one kiln at a time, depending on the size of the pieces. Some wood like mesquite takes only 2 1/2 weeks in the summer. This will bring the mc down to around 6%. The temp is maintain at 100 deg with a thermostat. If you need more info email me, I would be glad to help.
