mating the extension bed to the mini-lathe
Carol - now in NC Nebraska
>What do I have to do (or have done) to the end of the lathe for the bed extension to mate properly?
Re: mating the extension bed to the mini-lathe
Yikes! You are snake bit.
Eddie Pacheco; San Jose, Ca.
>Not sure when Jet made that change. Mine (non VS)has a milled surface on the end and two mating holes for the extension. Yours looks like just an as cast surface.
Stuart Johnson
>Is it possible the holes for the extension are plugged or some how skinned over. You could see if they are from the inside.
>No such luck.
I got my lathe used. It must have been manufactured before an extension bed was a glimmer in anyone's eye.
I have a metal working mill lathe at home that I know very little about. I wonder if there is a way to mill a flat surface....????
Scott Hurley in N. VA
>Mine had 2 threaded holes for attaching the bed extension, but I still had to "adjust" things to get it to mate correctly. Even after that, I had to file off the inside edges of the ways right at the junction in order to get my tailstock to slide smoothly over it.
Scott
Re: Yikes! You are snake bit.
>Snake bit? Yikes!
Its just a cast surface.
Let's see how many ideas we can come up.
Grind off the paint. Lather the end with Bondo. File/mill flat. Transfer holes and bolt together. A little paint and bob's your uncle?
Wow! As you said, Carol, I guess you will
henthorn
>just have to clamp the extension to the bed and line it up as accurately as you can and then mark, drill and tap the attachment holes. The end of the ways and the end of the extension should be flattened and squared first and for me that would mean careful grinding, filing and constant checking to do that. Looks like a difficult but doable job. I would think your level of craftsmanship would handle it. Good Luck.
Re: That is very close to my solution, Carol.
Al Crandall -NW of Indy-
>I'm sure you won't have any trouble jigging the extension so that the two beds are lying in the same plane, and the bed gaps follow parallel to a common centerline. My preference is JB Weld over Bondo, held in place with a dam of duct tape. There is no shame in through bolting with a lock nut if you dont want to bother drilling and tapping one side of the joint. I would add a couple of roll pins or spring pins to dowel the assembly together. If you want to be able to remove the extension easily after casting the joint closure, I'd lightly grease one side of the joint with vaseline or cover it with Saran Wrap prior to casting. You have a lathe which predates the easy mate up extensions of today.
Carol, make a template first
Atwerz
>Make a template first out of thin cardboard or stiff paper of the milled end of the bed extension, exactly. Tape this to the end of the lathe, exactly. drill the holes, exactly per the template. I guess bondo or something gobbed on the end of the extension. Use bolts to hold the extension lined up exactly and taught until set. When this doesn't work buy a new Jet mini EVS when they come out
Re: response to Al's solution - long but need help
>If I interpret your suggestion correctly, Al, I should line things up first. Given that I want to be able to remove the extension when unneeded.
Check me out on this sequence.
Remove tailstock.
Remove headstock and motor. (Gonna do that anyway to install the new DC variable speed reversible set up being built on my kitchen counter at the moment.)
Remove the paint from the lathe bed end.
Rip a board that matches the gap snuggly.
Lay everything upside down on my kitchen counter (reasonable flat and the only surface I have at the moment for the job.)
Butt the extension against the lathe bed end.
Insert the alignment board.
Transfer punch the hole centers from the extension bed.
Drill and tap the holes.
Bolt the two together and see what kind of a gap I have to deal with.
Unfasten and separate.
Stick clear packing tape on the bed extension end. Holds more securely that Saran wrap.
NOW HERE IS WHERE I HAVE A QUESTION OR THREE!!
If the gap is small (which I suspect it is), can I bolt the two together and insert JB Weld? Is the stuff thick or runny? I understand about making a duct tape dam. How do I keep from 'welding' the threads of the bolts to the patch? What about air pockets where the JB Weld didn't get? Never used the stuff. Have no idea what I am dealing with.
After the patch is done, then bolt things together making sure all is aligned properly. Then drill pin hole and insert pins for quick alignment in future attachments and detachments.
Then make a long rod with a M2 taper on each end to check alignment of the tailstock center to the spindle center. I gotta find a machine shop buddy! :) Maybe I should have that first!
Uh, uhm,,,,hey, Carol,
>You're going to some sort of ministry school, right? I'm pretty confident that there is a local machine shop or machinist that would mill that casting flat for free or close to free in exchange for a few, much needed, good words on Sunday. A machinist that's a biker?...Now those guys need ALL of the good karma they can get.
>Carol, You are as bad as I am. Aren't you doing $500 worth of work on a $200 item? I think your idea as you listed it would work. If you drilled and tapped the mating holes and they lined up nicely , just grease them and the bolts with Vaseline and slather the end with JB Well and bolt it up. The Vaseline will serve as a release agent. Clean up the squeeze out before it sets. Definitely a place to do a dry run first.
But, Couldn't you just buy another bed extension and replace the bed of the lathe with it? Never mind, then you would want to bolt the old bed on for an even longer lathe.
Also, I doubt the alignment of the tailstock and headstock matter much once they are more than a few inches apart. Since you are hand turning the table legs ore whatever, you would just adjust the banjo as you go. It's not like a milling machine that runs a cutter exactly parallel to the ways.
bhenr99
>Jet used to put a template with the extension when you bought it. Call Jet and they should send you a template.
Bob
I Was Thinking the Same Thing
Barbara Gill, Remlik VA
Re: Gees, folks...
>I never considered swapping sermons for services. What a concept!! Wonder why no one else is doing it??? :)
Re: Gees, folks...
>You could ever personalize the sermon to highlight their "sins". LOL not!
Re: Gees, folks...
don lewonczyk
>Im sure they don't want a sermon,tell them you will pray for them to be healthy, rich and happy! Your problem could be resolved if 40 people on WC sent you $5 each and in turn you turn something and donate it to WC for auction closing the circle. It would be hard for one or two to help but a little from alot of people wouldn't hurt to bad, what a few cups of coffee a couple of donuts? Its worth $5 to help someone from this site,people use it to show case there skills get free advice from people who been there done that. Don't everyone jump at once. Whats your mailing address Carol? I'll be first and im sure many will follow. DonL
Re: Gees, folks...
>Thanks for the offer, Don, but drop your offering in the plate at church on Sunday. We'll let God use it where He will.
Back to what I think set this off, I do have a metal mill. I don't know much about how to use it yet. When I get home I'll try to find someone to mentor me on the thing. Then I'll mill some M2's and make some alignment jigs for myself. Anyone know a retired machinist in the mountains of northeast Arizona that might want to show me how to do a few things on my mill?
As for turning something and putting it up for auction to benefit Wood Central, I think I am quite a way away from being good enough for that! But since everyone already knows Ellis' address, why not pop a donation his way for this site? We'll just skip the auction for now....
But thanks for your thought. Your heart is definitely in the right place!
Carol,Carol,Carol....
>Trust me, you don't want to find a retired machinist, in the the mountains of northeast Arizona, to show you how to do a few things on your mill...Ken Oakley will 2nd my advice on this....:-)
Re: Eddie, Eddie, Eddie....
>I have no reason to distrust you, Eddie, but you will have to explain why you feel the need to protect me from retired machinists in the
northeast mountains of Arizona who might be willing to show me a thing or two. Maybe even about my mill. LOL!
And how is that you are in cahoots with Ken?
This inquiring mind is puzzled.....hmmmmm????
Well,
>I'd hate to see some good ministry schoolin' go to waste. You know, just looking out for you, girl. Machinists, especially retired, lonely ones are smooth operators and a fine, hardy, woman like you could be tempting....:-)
I've worked with machinists and have dealt with a lot of machine shops so a fair amount of their extracurricular thinking has rubbed off.
Ken Oakley is ex Navy and a former toolmaker. He and I often share the same perverse thoughts...
Re: Well,
>Fear not, the ministry schooling is not going to go to waste! But we all need a hobby!
As for Navy types, I lived in San Diego county for 25 years. I know my way around a sailor or three. :)
However, I do thank you for your concern. It is good to have fellow woodworkers look after one another.
Carol
from the Routerlady to Pastor
Gee, think I should get new tee shirts?
Router lady to pastor
>Carol If I went from woodturner to pastor you know what would probably freeze over but you never know where life takes you. :)
Re: Router lady to pastor
>Not a chance, John! You are far too kind and generous to cause a major freeze of hot spots!
