Re: DIY Vaccum Kilns Article - 7% MC in 3 days
Dick Coers
>Here is the reply I got from Den on the Forestryforum. If I read his work correctly, he is an engineer at a vacuum kiln manufacturer.
"The heat from the bulb is not radiant but convective because of the fan. A 100W light bulb could produce enough heat to dry one board foot in 13 to 20 hours if you could get all of the heat into the wood.
He is running it as a discontinuous vac. He says in pulls the pressure down a couple times a day.
And, as mentioned in the past, water gets in the oil of the pump."
The machines that Den engineers have aluminum extrusions that go between each layer of lumber, and they pass hot water in those. That puts the heat in full contact with the wood. They have a chiller that cools a coil inside the chamber and the moisture condenses on it and is drained out. Of course the coil is stainless steel.
There was also some discussion on the forestryforum about putting a slab in a vacuum bag and submerging it in hot water. That would work well except it's one slab, the bag can not have any pin holes, how do you keep the water warm and circulated................
I was looking at all this when I had the brainstorm (maybe brain fart, LOL) about turning all the monster urban logs that my city grinds into chips, into endgrain flooring tile. My thought was that even soft maple wears forever on the end grain, and even siberian elm would have a good look on end grain, and mineral stained and spalted would be even more valuable. Just the perfect use for all those low grade logs. I asked Den about this and he told me that 1' to 1 1/2"end grain blocks would dry in a single day in his companies kilns. So if there are any venture capitalists watching......... I have to get in the shop and stop this dreaming. Gotta make some chips and break down some of the logs into vessels that I can't sell either. LOL
