OT - Deep scanning PC
don at central illinois
>My PC here at work has been acting up a little. Running really slow, etc. I have AVG, Spybot S&D and Adaware and have run all of them but still running slow. Does anyone know of some cheap or freeware that will do more than these? As always, TIA.
Re: OT - Deep scanning PC
GaryG in MD
>It's probably because you have all that stuff running. ;-)
Actually, slow performance is usually related to too-little physical memory (or too much memory usage, depending on how you want to look at it). Bring up your Task Manager and click the "Performance" tab to see what fraction of your memory is in use. If it's high, you can click the "Processes" tab to see what program(s) is/are hogging it.
...Gary
>I seem to be running in the 18 - 23% range. Doesn't seem high enough to cause major slow downs. I'll keep monitoring it. Thanks for the tip.
Bill Hale / The Wood Spinner
>If you have all of those they will slow you down. Also Norton and the other fancy programs lead to slow down.
I just removed Norton from my computer and went to a freeware program called AVG Free. Things speed-ed way up.
Run your scans etc. from Windows itself.
Bill in CG, AZ.
>One thing I forgot to say is you need to remove the other programs, not just the icon, prior to installing AVG.
Bill
Re: Bill- how sure are you that ......
Jamie Donaldson
>....you actually removed Norton? I deleted it about a year ago and find elements of it are still on my 'puter, and I have used several utilities, including 1 from Norton, to clear it completely. My other software says that some kind of Norton worm finder is still hiding inside the box, and I don't know how to find it!!
Jim Rutten
>How long has it been since you defragged your hard drive?
Re: About a month- made no difference.
Jamie Donaldson
>I know just enough to be danderous but. I also was running slow I had the computer guy that keeps all of our business equipment running stop by the house. He checked it and said " Dump Norton" I did and we installed AVG and it runns much faster now.
Bill
Carole Valentine
>How old is your hard drive? If I were you, I would backup anything important to CD or some other media very soon.
The MountainMan
>Hi Don!
Do you happen to be running Microsofts free worm software?? Man that was killing my system for a long time and I couldn't figure out why; my new laptop was going so slowly!! I was researching about s/w that can slow your system down I found a discussion about it, deleted the s/w (thru Control Pannel) and that was it!! If you are running the worm s/w - its product icon shows up as kind of a "medievel castle"
Regards
TheMountainMan
Re:-Mountain Man- I just tried turning off.....
Jamie Donaldson
>....the Windows firewall and a balloon popped up to tell that Norton worm remover was not working? I've been trying to delete all traces of Norton for a year, and is it possible that it's hiding in Windows firewall? The laptop seems to be a bit faster, and I'm running Spybot S&D, PCTools antivirus, and whatever AOL has n their security bundle. I wish that I was techie enough to figure all this stuff out!
Don, another thing you might check...
GaryG in MD
>Have you deleted your cookies recently? If you don't have an on-going cookie deletion protocol, they can grow into a really huge file and clog up the works. It's a good idea to order them by date of last use and delete all but the last few months worth -- or more (sometimes a clean slate is best). ...Gary
