Loose Chuck
Loose Chuck
Loose Chuck
TomCollins
>I have a Delta Midi. My Grizzly chuck is very loose on the spindle shaft until it buts up against the shoulder on the shaft. I think this is why I have so much trouble with things being out of round. Looking on the Delta site a new spindle shaft would be back ordered until July '08 and the machining probably wouldn't be any better.
1.) Would there be a way to improve the threads on the spindle
shaft that I have?
2.) Many of the mini's are very similar in appearance and I'm
wondering if possibly a shaft from say a Jet non-vs may
work.
3.) Would any of you Jet mini non-vs owners be able to give
me the part number for the spindle shaft from the Jet so
I can check specs out with Jet
I recently bought an adapter from PSI so I can mount my chuck in the tail stock. The adapter and my chuck fit together like silk..no slop.
TIA,
Tom
Re: Loose Chuck
Re: Loose Chuck
Ronnie
>I have the Delta 45-715 and a One Way chuck.It also has slop untill it hits home but I have no problem with out of round.Maybe your wood is warping while your turning ,I have had this to happen on occasion if I have to leave it for any length of time. I made a Longworth chuck[if thats what it's called] that wouldn't run true untill I put a spacer,washer, between it and the shoulder of the spindle.You could try that before tearing into your machine.
Ronnie
Re: Loose Chuck
Re: Loose Chuck
Mike Brazeau
>Tom - are you using the fat washer that comes with the Delta midi?
Re: Loose Chuck
Re: Loose Chuck
Bart Rhoads
>Just an idea but I was wondering if you could wrap some Teflon pipe tape around the spindle to fill in the excess gap in the threads. It would be a temporary fix though.
Re: Loose Chuck
Re: Loose Chuck
Dave Peebles Lyons, Ohio!
>Hi Tom,
I have three Oneway Talons here in the shop. I don't have another class till the 25th of February. Feel free to come and borrow one to see if it is the chuck or the spindle that is causing you problems. I will be in the shop all day tomorrow working on handles.
Give me a call
Dave
Re: Loose Chuck
Re: Loose Chuck
Kevin Clay
>If the chuck butts up tight to the spindle that is not the cause of things being out of round. If the chuck was loose you would get vibration problems not out of round.
regards
Kevin
Re: Loose Chuck
Re: Loose Chuck
>Tom,
I checked my chucks yesterday on two lathes and re-read your message. Until tightened and seated against the shoulder, ALL of the chucks feel loose on the threads on both lathes. The questions are then, how loose is yours and how loose is too loose?
I suspect you imagine that the chuck being loose on the threads might allow it to be off center by some small random amount when tightened. If so, this would not make the work "out of round", as Kevin said, but just offset a piece slightly if the chuck is removed then retightened. However, it seems to me the thread geometry would tend to center the chuck as it was tightened, unless the mating surfaces between the lathe and chuck were very rough with high friction. In this case, a bit of smoothing and/or lubrications might help.
If the piece is actually out of round after being turned or partially turned, it seems to me it must be from shrinkage or warping, as Ronnie mentioned. Perhaps you can describe in more detail what you mean by "out of round".
Re: Loose Chuck
Re: Loose Chuck
don lewonczyk
>Just a question for you. Is the work piece your putting in the chuck square on the end and butted up flush (bottomed out in the chuck) all the way? It doesn't take much for your turning to look or be out of round, tighting the jaws don't mean the stock will be square. Just my experience with a couple of boxes I had trouble with and thats what caused it. DonL
Re: Loose Chuck
Re: Loose Chuck
Bill Hale / The Wood Spinner
>Tom
Are you turning wet or dry wood. If wet and it dries even a little it will go out of round. If I don't finish a rough out in one standing the piece gets wrapped in a plastic trash bag. I do all my work between centers at rough. I turn a spigot on the bottom and when the pieces dry I have to return the spigot and the bowl to round for finish turning.
Good turning and be safe
Bill in CG, AZ.
Re: Loose Chuck
perhaps,
Jorge Castaneda~Downeast Maine
>The points do not meet squarely, like in my lathe, so it is always exccentric, but not so much as to make me abandon it...
Jorge
Re: Loose Chuck
I Think
TomCollins
>its a combination of a number of the things mentioned above. I didn't realize there was a washer that went on the spindle but I vaguely remembered unpacking it. I have a different chuck to try so I will see if that helps.
Thanks for your suggestions
Tom
