Keith Newton
Keith Newton
Keith Newton
Bill Hale / The Wood Spinner
>About the vacuum chamber. I am getting a 20" Dia x 30" long piece of heavy wall steel pipe. I just priced a Steel flange and fell out of my seat. Cap and flange almost $ 600.00. Change of plan needless to say. What do you think of welding one end closed and machining the other end flat? Then add a top plate and duct tape it on? Do you think I will need to have this machined flat to seal?
Thanks Bill in CG, AZ.
Re: Keith Newton
Re: Vacuum chamber
Carol - now in NC Nebraska
>Well Bill, you got me looking into vacuum fixtures again. :)
Weld one end closed. Make sure there are no pin holes in the weld.
Machine the other end flat. Get some closed-cell foam insulation 'tape' and stick it one the newly flattened edges. Scarf the ends. Lay a flat piece of steel or thick plastic on the top and pull your vacuum. Piece of cake. You are good to go. No duct tape needed. The vacuum will hold the lid in place.
Now you have me designing a new vacuum pump project for my mini-lathe. :)
Re: Keith Newton
Re: Vacuum chamber
charlie belden
>See message
DIY Vaccum Kilns Article - 7% MC in 3 days
(note: the linked pdf file is 2.5 Mb so dial-up users be aware)
Re: Keith Newton
Gosh, way too much work.
Eddie Pacheco; San Jose, Ca.
>Is this is just for drying wood/wood turnings? The most Vac. it will see is 28" Hg just get some 1/2" 04 3/4" black radiator hose or clear vinyl house and slit the hose along the length. Use this slitted hose to make a grommett at each pipe end. Use RTV silicone seal to fill in the gap or seam where the hose ends butt. Drill and tap the pipe wall for a fitting. When a vacuum is drawn any suitable 1/2" flat steel or 1 1/2" ply flooring end caps should be drawn tight by the vacuum after being held in place somehow.
The setup Charlie Belden posted is pretty good too.
It's not like you're going to be plating silicon wafers and need 4 x 10 neg3 mbar of vac.
Re: Keith Newton
Re: Keith Newton
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>Hey Bill, I just found you question to me on WC turning forum. Did you see Charlie Belden's link in the forum to an article. The PVC article sounds pretty good to me if you are looking for and easy material to work.
It has been several years since I was experimenting with this, before I gave up for lack of coming up with an idea for an easy heat source, then removing the vapor before it went into the pump. From what I have read, this can be very corrosive and will ruin a good pump.
I was taking it out and zapping it then putting it back in for a quick suck over and over just to experiment. After fooling with it for a while, I got bored with it and came to my senses. Almost all of my turning is green, then carved, also green, and I don't care if it changes dimensions, and takes a couple of weeks in a paper sack.
At the time I was trying to get some work ready for a show, and trying to speed things along to get them finished.
If you are just wanting to experiment, I wouldn't get bogged down in a lot of work building a industrial strength tank. I do a fair amount of vacuum bagging, and have been for about 20 years, and keep coming up with little tricks to do creative things. One thing that I came up with a few years ago was to get 55 gallon drum liners. A box of 80 cost about $12. They are clear and tough. You could put a length of PVC or any kind of pipe with a plywood end inside of one of these bags, to make the seal.
To seal the bag, I just cut a small hole in the bottom in one corner. I cut it smaller than the hose, so it stretches to shove the hose in, then wrap a few wraps of rope caulk around the hose inside the bag, and smuch the bag down tight to it where the hose enters. You could use chewing gum or anything soft and sticky, even regular caulk.
I seal the open end by rolling the excess around a thin strip of wood, then spring clamping another one to it, pinching the wraps together. As long as there are no sharp parts to pierce the bag, it will conform to any kind of chamber which will stand up to the weight of the atmosphere. Keep in mind that at 28" hg, this is close to one ton per sq. ft.
If there is a good metal recycle yard anywhere near you, there will always be something there that you can find to experiment with.
When I quit fooling with this, I was thinking of allowing a small trickle of air to enter the chamber through some sort of heated tube so that all of the air entering would be warm enough to cause the evaporation, and carry away the steam.
